Welding on crawler idler wheels
Results 1 to 10 of 10
    Oct 2009
    Looking for some advice. A friend of mine has a crawler with the idlers wore pretty bad on the outside so he keeps throwing track. He has asked me to fix the problem. There is room to build them up so was thinking of getting some AR-400 or some type of AR plate rolled to the correct dia. and welding with 7018. There would only be the one pass on the inside. The outside will take multiple passes. Do I need to worry about bearing shrinkage? Is there a better rod/material I could be using. I have'nt done much heavy equipment like I know some of you have. Thanks.
    :help
    I am new to this stuff ( my first post ) so if it's all messed up forgive my ignorance.
    Dutchman
    Sep 2009
    Re: Welding on crawler idler wheels
    Welding a separate piece of metal in won't hold up, you need to build up with rod or wire.
    Use a good build-up rod or wire; Stoody, Postalloy, Rankin among others make this. 7018 will give less than acceptable results, it tends to mushroom out under pressure. You don't want to make it extremely hard, if you do you could accelerate the wear on the track links.
    Oct 2007
    Vandalia, Ohio near Dayton
    I'm not sure I understand the specific application, but I'd recommend a stronger electrode than 7018 if you're welding AR plate. 9018 or 10018 would be a better match for mechanicals. You should also look at preheat, depending on the thickness of the base metals involved.
    Oct 2007
    jsfab and I were posting together. If using a buildup and hardfacing electrode is right for this application, that would be the best way to go. Make sure to get a hardfacing electrode with the correct properties; a product with balanced metal-to-metal wear and metal-to-earth wear resistance would probably be best.
    Talk to a customer rep for one of the companies mentioned, or Hobart or Lincoln for that matter, and get their advice one which products and procedures will produce the best results.
    Oct 2009
    That smile is for the quick response. Thanks a bunch. The last thing a person wants to do is mess up a job. I will look into building up instead of the AR. I have a Trailblazer 302 so wire or rod either one is an option. Any preferences ? Oh,the idlers are not off the crawler yet but I am thinking they are probably running on a tapered roller bearings. That is why I was wondering about the shrinkage.
    Dutchman
    reno
    they actually usually run on a large bushing and are sealed with duo-cone seals and filled with oil
    unless you are working on something totally obsolete, its usually hard to beat the cost of a reman unit
    Sep 2009
    Nevadanick is correct about the remanufactured parts.
    In any case, a person should find, and correct if possible, the cause of the uneven wear before running the crawler again.
    Aug 2008
    Dansville NY
    Hi Ya oneweldingpapa and Welcome to the Welding Web Family. You best bet for a proper response to your questions would be to post them in the General Welding Questions forum.
    Oct 2009
    Thanks specter for that input. I passed the info on to my friend and he's going to decide what he wants to do. The crawler is not that old. It's a smaller komatsu that does not get that much use. I believe the reason the idlers are wearing the way they are is because there is way to much tension on the tracks but cannot convince otherwise. I will let you all know how everything turns out if he decides to go ahead with the fix.
    Thank all of you for the advice and the welcome. I really like the forum.
    Dutchman
    Nov 2008
    There should be a noticeable sag in the tracks on top of the top idler.
    If he is throwing track, the other track components could be worn, most importantly the pins and bushings. Have they been turned? How do they feel? Egg shaped? If they are, then they need to be turned as well. Most of the track throws I have encountered have actually been from worn sprockets...If the sprockets are pointed or sharp, they need to be replaced. They should be a rounded or dull tip to the point of the sprocket.
    As far as building up goes, I have seen some good buildup take place with 309L. Although it might not be as good as some other hardfacing rods, it works pretty well.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
