Structual AWS D.1.1 certification questions
Results 1 to 8 of 8
    Sep 2009
    My class is going towards getting this certification. Some students have uncovered different certification specs. Main question is this: While piece remains tacked, can you use a grinder / wire wheel on your weld?
    Jun 2008
    Agawam Mass
    Re: Structual AWS D.1.1 certification questions
    I am not sure what D.1.1 saws about that. I know through my union we are not allowed to use any powered tools to clean the coupon not even a wire wheel. I also know that in MA and CT you are not allowed to use power tools to take a DOT test.
    Honestly if you clean well with good sharp chipping hammer and a wire brush you should be good. I always bring a small and large wire brush, a scratching awl, sharp chipping hammer and a small and sharp chisel and a small ball peen hammer to use with the chisel. No need for power tools to pass this test.
    Sep 2008
    SF bay area, CA
    Yes, as per AWS D1.1 you can use any powered tool you choose.
    Nov 2011
    North Idaho
    Around here in addition to a AWS cert you need a WABO ( state of washington ) cert. for structural steel. The AWS and wabo are generally the same test except no grinding on the root or the cover pass. Additionally any grind marks outside the groove are a bust. So most local testers do NOT let you use grinders on the test, except pipe tests.
    The other requirement is the machine needs to zero'd out so you know how to set it up.
    My thought is your in trouble if you need a grinder on a test, and need more practice.
    Nov 2011
    North Idaho
    A tool you can use, is a small sharp chisel, or a file ground sharp. I find that the chisel stays sharper than a chipping hammer and a couple of quick swipes is all you need to clean off/out your weld.
    Sep 2006
    Marlborough, The Peoples Republik of MA
    If I have to take a no grind test I have a nice big pipeliner file modified just for the purpose.
    Jan 2012
    If you think you need a grinder your not ready for the test .
    Feb 2012
    ny
    Quote Originally Posted by TozziWelding View Post
    Yeah tozzi, same here. Hammer, chisel and a hacksaw blade was all I used. Ah the youth of today. They probably get to test in an airconditioned room as well "gotta keep the proctors computer cool"
    I hate being bi-polar it's awsome
    My Heroes Have Always Been Cowboys
