Heat box fort sa 200
Results 1 to 9 of 9
  1. Heat box fort sa 200
    Trying to wire up my (heat box) remote to my sa 200 welding machine. Got the grinder to work. But when switched to remote it will not weld.
    Using Tapatalk
    May 2008
    Orange, TX
    Re: Heat box fort sa 200
    Need a bit more info.
    What remote schematic did you follow?
    LOCAL/REMOTE switch or in series with panel rheostat?
    What are you using for your connection from the machine to your remote?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
  3. Re: Heat box fort sa 200
    Switch. 12/2 extension cord
    Using Tapatalk
    May 2008
    Orange, TX
    Need a 3-conductor extension cord.
    The ground conductor in the cord is used for the rheostat "return". As such, if the auxiliary power outlet is used for the remote, it absolutely needs to be one of the isolated ground version.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
  5. Re: Heat box fort sa 200
    It is. I covered all the basic. Even put another rheostat in the box. I ether got a wire messes up or a bad switch. Which the switch is brand new also.
    Using Tapatalk
  6. Re: Heat box fort sa 200
    I have hooked up a total of four machines so far and this one has got me.
    Using Tapatalk
  7. Re: Heat box fort sa 200
    Do you have a diagram I could trace my wires
    With?
    Using Tapatalk
    May 2008
    Orange, TX
    Then I'd run back over everything one circuit and component at a time.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
  9. Re: Heat box fort sa 200
    So I fixed it. When I come back looked had two wires flipped. Worked like brand new
    Using Tapatalk
