Spot welding problems
Results 1 to 4 of 4
    First, let me start by saying I am not a welder and have gained new respect for the field since I have been given the responsibility of resolving this problem.
    I have a Miller shop master welder. It has a spot weld setting with adjustable spot time, wire feed rate, burn back, amperage, etc.
    I am welding a piece of stainless steel hinge to a 1/4" thick piece of aluminum. it is a 6061 or 6063 grade alum. The hinge has a .125 hole in it. I keep having problems with inconsistent welds. a majority of time time I get a big build up on the front side with a lot of splatter and adhesion to the nozzle but no penetration through the back side. I can pull it apart very easily Then some times it will blow a hole right through without changing a setting. I have suspended the feed cable from the machine to the gun from the ceiling to ensure a good consistent feed path. Occasionally it will weld perfectly with a nice pretty puddle on the front and a tiny nipple on the back side and I can't pull it apart. I have tried adjusting all the settings and had a repair tech out several times. When he left the first day it was working ok and then it went back to incosistency without changing any settings. I read on another thread that it could be because I am using 75/25 argon nitrogen mix and I should try using pure argon. can anyone offer any advice?
    Feb 2009
    Re: Spot welding problems
    I would never consider welding stainless (or any steel) to alum.
    "SOUTHPAW"
    A wise person learns from another persons mistakes;
    A smart person learns from their own mistakes;
    But, a stupid person.............never learns.
    Jun 2008
    Central California
    I am curious who came up with this idea; do you work in a factory or shop where somebody above you in management decided this was a good idea, or are you a new employee who was just given this assignment by the other workers?
    Welding aluminum to steel, be it carbon or stainless, is sort of like mixing oil and water; it can be done by some exotic means, but the results you now have are what you'd expect from your method, if you understood the properties of these metals.
    Feb 2009
    Melbourne, Australia
    Need a little more then a Miller Shop Master....
    Fronius Cold Weld
    http://www.fronius.com/cps/rde/xchg/...8_ENG_HTML.htm
    Lots of $$$$
