Grader blade for bucket cutting edge?
Results 1 to 6 of 6
    I've read some of the bucket cutting edge replacement projects and was wondering if anyone has used an old grader blade for a replacement cutting edge. My question is how do you handle the curve in grader blade. Also would you put the cleaner bolted edge in front? Thanks.
    Aug 2006
    St. Paul Park MN
    Re: Grader blade for bucket cutting edge?
    You will be a lot happier in the end if you buy the right flat cutting edge blank.
    You're probably right. Just wondering if anyone had done it.
    I was wondering the same thing...I have 10-12 used grader blades with minimal to heavy wear...and a backhoe that is in dire need of a replacement...hmm free or spend money on the right one the first time around?
    Mar 2009
    Iowa
    I've only found one thing that used grader blades are good for.......scrap. I have a farmer friend that had an entire pusher blade for his tractor made out of old grader blades. I got tired of fixing it so I built him a new one and just charged him for the steel. Fooker traded it off shortly after that. He did the same thing with a trailer I built for him, same deal, steel only. I now bill him for everything. And sold him my old trailer to replace the one he traded.
    My name's not Jim....
    Mar 2009
    Oklahoma
    If you have a jacked up bucket it will work but i would not do it on a good bucket.
    Millermatic DVI
    Millermatic 251
    Older buzz box
    Cheap 120 welder
