Injection Pump Issues
Results 1 to 7 of 7
    May 2009
    Elgin Tx
    I have a 2001 Dodge cummins and this truck is on it's 4th inj. pump in 240k miles. Could the leads be causing a magnetec feild or something like that. I have the leads wraped old school stye on the side of the truck. They are not wraped together they are seperate spools. I have tryed everything all grounds have been cleaned. I dont weld on truck. And I run Amsoil fuel lubricant in the tank every fill up. Can anybody thing of anything else?
    1990 SA 200
    Miller 225
    Rip Miller302
    Miller 135
    Lincoln 200 Mig
    Hypertherm 600 Plasma
    Plasma Cam Cutting Table
    Mikita Cold Saw
    JL Welding Tx . com
    Dec 2008
    from Timber Country to the Golden Triangle
    Re: Injection Pump Issues
    junk diesel
    Mike
    Constans Fides et Integritas
    Lincoln Weldanpower 150 AC
    Airco Aircomatic MIGet CAV II w/ spoolgun
    Millermatic 30a wirefeeder
    Sep 2007
    Rochester, WA
    mmm... is that a 12 valve with the bosch injector pump?? I dont remember what year they switched to the 24. Anyhow, those mechanical pumps in the older diesels shouldnt be failing that often you would think. It might help some if you could describe exactly how it is failing?? And just to specify you are saying the pump is malfunctioning and not the injector? ( are you on your fourth pump or fourth injector?)Are you running stock injectors? Have you turned up the pump? Do you tow etc...
    2011 Dodge 3500 diesel dually
    Lincoln SA-200
    Lincoln SAE-300
    LN-25's
    Lincoln Idealarc R3R
    Miller Trailblazer 302
    Apr 2008
    Yuma AZ
    Your lift pump is failing. You need to replace that, or add in another electric pump. Pretty common actually. I think if the fuel pressure (from the lift pump) drops much below 10psi, the injection pump isn't getting enough fuel to cool the pump, which causes it to swell from the heat & bind up.
    Do a search on Diesel Power, it explains it quite well. And yes there are kits out there for it.
    Mark
    Craftsman 12"x36" Lathe
    Enco G-30B Mill
    Hobart Handler 175
    Lincoln WeldandPower 225 AC/DC G-7 CV/CC
    Add a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG
    PapaLion's Gate Build
    Jan 2010
    1000 miles from nowhere........
    Quote Originally Posted by JLWelding View Post
    I have heard of your story, before. The people who told it, didn't weld, though.
    Have you tried http://www.cumminsforum.com/forum/ for any answers? There is a lot of good information.
    How about Industrial Injection, (http://www.industrialinjection.com/) for a good replacement. They have a good reputation.
    I hope that this helps......
    -Rhyno
    07 Fowler 200D
    65 RedFace
    04 Miller TB 302, 22hp
    Miller 12RC
    Miller HF 251-1
    Lincoln SP135
    HyperTherm PM 380
    and a few others...
    Quote Originally Posted by Rhyno View Post
    But, if I "all of a sudden disappear.... ...." hopefully I didn't suffer too much....
    Apr 2008
    Yuma AZ
    May 2009
    Elgin Tx
    Thanks for the replys
    1990 SA 200
    Miller 225
    Rip Miller302
    Miller 135
    Lincoln 200 Mig
    Mikita Cold Saw
    JL Welding Tx . com
