Bad rod or bad welding
Results 1 to 16 of 16
    May 2010
    ct.
    Last week I was practicing with 7018,it was coming out REALLY well.
    Today not so well.Aside from undercutting and inconsistant travel speed
    (my fault)there are holes in the weld.Is this porosity or just bad welding?
    There doesn't appear to be any slag in the holes.
    I've had rod for about 2 months and don't have an oven.
    The rod has been kept in one of those plastic tubes with the screw on gasketed lids.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    Aug 2007
    Re: Bad rod or bad welding
    It could go either way, I have used rods that have been outside an oven longer than that with no SURFACE porosity. I have also used rods straight from the oven and gotten porosity.
    You could also be holding to tight or too long of an arc gap, but its impossible to tell what your problem is from that picture.
    I would get a few pounds of fresh rods and try that and see what happens.
    Have we all gone mad?
    Jan 2006
    In A Nice Comfy Chair
    Quote Originally Posted by sn0border88 View Post
    Yup..
    I would also SLow down a bit..
    What size rod and what amps are we running?
    I take it it's practice for the shaft?
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Another potential cause for porosity is contamination. Is the plate clean? Is it covered in rust from sitting outside? It dosn't take much to cause a problem in certain conditions.
    Scott
    Welders360
    New guy.
    May 2010
    ct.
    Zapster-Its 1/8 7018ac rod(Ibought ac accidentilly).
    I'm running 110 amps,electrode positive.I tried using elctrode neg.
    Everything was the same as last week,when welds turned out so well.
    Yes I was practicing for welding shaft.
    Scot-steel was not rusty ,fairly clean.
    Millermatic 180
    Purox O/A
    Aug 2008
    If you're running 7018AC, RUN IT ON AC
    It will give you a good bead, different, but a good bead
    Turn the machine up to around 135amps, and let it burn
    some pics of 7018Ac to follow, if I can dig them up
    Porosity can be, like others said, a function of too long an arc. Don't immediately think it's "wet" rods.
    http://www.farmersamm.com/
    San Diego, CA
    I agree with sam (not only because he is a much better welder than I but also because I love that cow in his pic!)
    HAHA
    I always run that rod at 135A and never get porosity in welds unless its on a cold start which is attributed to my bad user error. I think from the pics you must be running it too cold. You dont have enough arc force to blow the crap out of the pool which is giving you what you see. Also if its AC rod run in on AC because thats what it was designed to run on.
    May 2010
    ct.
    I just now tried using it with ac 135 amps.seemed to work better.I'll try it on a groove or fillet
    later.I had been successfully using that rod with dc.
    Millermatic 180
    Purox O/A
    Feb 2004
    BULVERDE, TX.
    AC rods will run just fine on DC. They just have more stabilizers in the flux to work better on AC...mainly the small AC Tombstones and units like that. The stabilizers don't do anything to hurt DC performance.
    If the 135a worked better, I'd say its possible you have a little moisture contamination. The higher amperage was able to overcome it. Running an 1/8...assuming 1/8 anyway....rod on 110a is kinda on the low side anyway. Fresh rods will make it easier, but once they get the moisture in them, the lower amperage will start biting you in the backside.
    QamuIs Heg qaq law' lorvIs yInqaq puS
    Aug 2008
    Don, aka DDA52 is the guru of stick.
    Well, one of the guru's. And most importantly..........my mentor
    If he says it'll run good on DC, I gotta believe it. Never did try to run it on DC.
    But when it comes to arc blow.............AC RULES
    Wrap the leads around the iron, put the clamp everywhere, including yer johnson, nothing beats blow like AC. NOTHING
    Pic...........very bad arc blow situation, everything but standing on my head, feet pointed south, nose pointed east, feet firmly planted on the ground. Nothing worked. AC SAVED THE DAY Not perfect, but a stable arc.
    Feb 2004
    BULVERDE, TX.
    I'm not a guru Sam. No way am I gonna sit on a mountain top all day long. That has to hurt.
    Actually, you did use AC rods Sam. The 3/32's I had you weld with were 7018-AC. You never even knew the difference.
    Jun 2010
    Iraq now, Farmersburg, IA is home
    From what I have learned is that the 7018 is a low hydrogen rod, that when exposed to air absorbs hydrogen and humidity. Which in turn makes for a poor weld. We always tried to use an oven to keep the 7018 warm, I don't remember the temp. So if your welds were good with freshly opened rod, and after the rod sat for a while, the welds kinda turned to "crap". You may want to try finding an old rod oven. Don't use the oven in the kitchen. We had an old fridge with a heat lamp in it at the shop for keeping rod in. Just a couple of suggestions.
    Nothing is fool-proof, to the substantially talented fool!
    Help me, I can't drink all of this beer myself.
    May 2010
    Sparks, NV
    7018 is only good for 4 hours after being opened per AWS specs then needs to go in rod oven cuz it absorbs moisture fast.
    AHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; ESAB 875 plasma;Evo 355. OA
    Jun 2010
    Thanks for the clarification, been awhile since I used 7018. Guys at my new job just can't understand about the differences in welding rod. Alot of the "We've been doing it this way for 30 years" mentality. So I don't even touch the 7018 that has been sitting out for years.
    May 2010
    ct.
    Cranking current up helped.Top weld is 7018 dc en 125 amps.
    Not perfect but closer to what I was doing before.
    Millermatic 180
    Purox O/A
    Feb 2004
    BULVERDE, TX.
    Try 135.
