What Generator can I use For Lincoin 225 Arc
Results 1 to 7 of 7
    May 2009
    I saw a generator at Home Depot for 300$ 5500 wats 30amp and was wondering if i can run my Lincoin 225 arc welder on it. How do i wire it up and should i look for a bigger generator that will go up to 50amp.
    Los Angeles
    Re: What Generator can I use For Lincoin 225 Arc
    http://www.lincolnelectric.com/knowl...generators.asp
    LINCOLN FAQ
    "It appears that a 5000 or 6000 watt 230 VAC generator is large enough to operate my AC/DC 225/125 using a 1/8 inch diameter E6010. Please confirm.
    It does appear (if you do the math) that you should be able to use 1/8 in. and smaller diameter electrodes with an AC/DC 225/125 powered by a 5000 or 6000 watt generator. Unfortunately, the design of the transformer on the AC/DC 225/125 is not efficient enough to be powered by a small generator. If you try and weld with this combination you will most likely experience the electrode being hard-to-strike and also the electrode frequently sticking to the work.
    If you are fortunate to establish an arc, the arc will tend to pop out frequently. Also, there will not be adequate heat input to the work, resulting in low weld quality (poor fusion), and poor bead appearance.
    To successfully run your AC/DC 225/125 welder you would need a minimum of a 15,000 watt AC generator."
    MM211 (Sold)
    Miller 125c Plasma 120v
    Mar 2006
    Oklahoma
    AMPS x VOLTS = WATTS
    50 x 220 = 11,000 watts
    and a surge to start arc so 15,000 is needed
    idealarc 250/250 ac-dc tig
    idealarc 250/250 ac-dc tig #2 used for stick
    lincoln sp100
    hh125
    dual arbor grinder polisher
    30 yrs of hand tools
    52 pitch blocks 6p-26p
    rake gauge -pitch gauge
    G&D prop repair
    918-207-6938
    Hulbert,okla 74441
    Mar 2007
    Vero Beach, Fl.
    x 3.......15,000 or better is needed to run that welder. By the time you buy a generator to power up that welder you may as well just go out and find a used engine drive welder. Probably cheaper in the long run and still be able to generate power for your other tools or in the event of a power failure.
    I am what I am, Deal with it!
    If necessity is the Mother of Invention, I must be the Father of Desperation!
    May 2009
    Thanks guys that will help. If i am not welding to the full capasity of the welder will it need that much voltage to arc. I usually weld on 1/4 inch steel use 3/32 rods 6013 or 7014
    Ca, USA
    If that's all you're welding with, consider a little Maxstar 150S inverter stick welder. The little welder can run off a 5KW portable genny, as it only pulls 20 amps or less on 220v single phase power. It can also run on 110v power with the included adapter plug kit. Typical price on the 150S is about $750.
    http://www.millerwelds.com/products/...maxstar_150_s/
    http://store.cyberweld.com/mima150sstwe.html
    MM350P/Python/Q300
    MM175/Q300
    DialarcHF
    HTP MIG200
    PowCon300SM
    Hypertherm380
    ThermalArc185
    Purox oa
    F350CrewCab4x4
    LoadNGo utilitybed
    Bobcat250
    XMT304/Optima/Spoolmatic
    Suitcase12RC/Q300
    Suitcase8RC/Q400
    Passport/Q300
    Smith op
    Jan 2008
    if you can get a satisfactory result with 6010 or 6011 you can use lots less machine...
