Millermatic 35 amd Spoolmate 3035
Results 1 to 5 of 5
    Oct 2010
    NJ
    Hello,
    I don't need to weld aluminum but I want to learn. I definitely need to weld stainless steel.
    I currently have a millermatic 35 white face welder with the spot welder panel (model SKP35). I will be getting a spoolmate 3035. I believe I also need the control box SGA-100 #043856.
    Is this machine worth the expense of 500.00 to set this up to weld aluminum and stainless and if so, is there anything else that I will need to weld aluminum and stainless? I currently have a argon/co2 tank. Maybe the purchase of a trimix tank?
    Any info will be greatly appreciated.
    banshee
    Feb 2008
    North of Philly
    Re: Millermatic 35 amd Spoolmate 3035
    To do alum, you will need 100% argon. You will either need to get another cylinder, or swap your current one for an argon one. I belive mix for stainless will depend on what stainless you are doing and what the requirements are as far as corrosion resistance.
    Ronald Reagan
    Ca, USA
    You don't need a spool gun to weld stainless. Put the wire in the machine and use the regular mig gun.
    Use tri-mix gas for stainless.
    Use 100% argon for aluminum.
    Use 100% co2, or argon/co2 mix gas for steel.
    I'm not sure the spool gun you have chosen is the right one for that machine or not. I have heard of folks using Spoolmatic 1 or Spoolmatic 3 guns on the old Miller Matic 35's. Might want to send a PM to Duaneb55. He knows the ins and outs of the old MM35's and what spool guns they work with.
    MM350P/Python/Q300
    MM175/Q300
    DialarcHF
    HTP MIG200
    PowCon300SM
    Hypertherm380
    ThermalArc185
    Purox oa
    F350CrewCab4x4
    LoadNGo utilitybed
    Bobcat250
    XMT304/Optima/Spoolmatic
    Suitcase12RC/Q300
    Suitcase8RC/Q400
    Passport/Q300
    Smith op
    Oct 2010
    NJ
    Thanks for the info DSW. I will have to first pickup another tank for the tri-mix and then another one for the Aluminum at another time.
    Oct 2010
    NJ
    Thanks to DesertRider33 for his info also. I came across the Miller spool gun hookup chart. On the first line of the chart it lists the MM35 uses spoolmate 185 with control box SGA-100 #043856. I also read that the spoolmate 185 is the same as the spoolmate 3035 gun. I may be wrong but that is what I read on the net.
    I have a chance of getting a new spoolmate 3035 for a reasonable price.
    I did talk to Duane55 in the beginning of the year and he informed me that I could install the spoolmate 3 onto this machine with a little electronics tweak. He was nice enough to send me the info on how to do it, just haven't had the time to investigate it yet but I will. I haven't been able to find a spoolmatic 3 yet.
    Thanks again...
