Welding cast iron to mild steel
Results 1 to 6 of 6
    Oct 2010
    For AC stick welding what is the best rod for welding cast iron gate finials to mild steel? The steel is 3/4 inch square tubular steel 1/8th inch thick. The finial has a 3/4 inch square cavity to accept the steel.
    Feb 2008
    North of Philly
    Re: Welding cast iron to mild steel
    My supplier recomends 7018 or mig for all his cast parts. Parts are often cast steel rather than true cast iron.
    Ronald Reagan
    Nov 2007
    some times i just use mig
    Oct 2009
    Austin TX
    Quote Originally Posted by jimrockireland View Post
    I always use nickle/iron sticks using DC + (positive) when welding my iron finials to the mild steel posts. Seems stronger and never had one crack.
    Miller Syncrowave 350
    Millermatic 252/ 30A spoolgun
    Miller Bobcat 225g w/ 3545 spoolgun
    Lincoln PowerArc4000
    Lincoln 175 Mig
    Lincoln 135 Mig
    Everlast 250EX Tig
    Century ac/dc 230 amp stick
    Victor O/A
    Hypertherm 1000 plasma
    Feb 2010
    upstate ny
    you can use a 18/8 stainless rod too.the alloy content lets it remain pretty stretchy even w/ the high carbon in the cast iron.haz will be brittle with any method
    lincoln weld pak 100 hd
    lincoln ranger 225gxt ac/dc
    oxy/acetylene
    puroxcw202
    victor fc100
    harris model 85
    harrismodel 16
    oxweld w24r
    oxweld w17
    glue. or er70s mig wire. I use epoxy. Construction adhesive works too> No need for special filler on something so non critical. If it is cold were you are keep your adhesive warm prior to use.
    On stuff like more critical like casting that might fall off use Nickel rod.
