ranger 8 fuel leak
Results 1 to 10 of 10
    Jan 2008
    ranger 8 fuel leak
    i filled my gas tank and fuel leaked from the top of what must be the fuel pump.i disconnected the hose from a straange-looking block below the carb, and when it drained down the leak stopped. cant get the parts list off thelinconsite,it wont download, and now ill try to get them on the phone for the diagram
    anyone have any experience with this type of problem? with the fuel drained down below that level it seems to work ok.
    Ceres, California
    Re: ranger 8 fuel leak
    code number please.
    Jan 2008
    9972..webssite will show me the manual but says the parts list has file issues and cant open..could be my computer..
    May 2008
    Orange, TX
    Worked for me. Try this link.
    http://content.lincolnelectric.com//...parts/P229.pdf
    No real engine parts detail though. You'll have to check out the engine brand website for that I suspect.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    4 out of the 5 voices in my head say "Go for it".
    Jan 2008
    thanks, duaneb..ill try on another computer..still getting that same computerese message..
    Jan 2008
    i got the parts list and it shows the leaking device to be a fuel gage assembly kit. i will go burn some rod and use up some more gas and pull the sucker out to see if it is fixable, before doing that ill ask my lws to see if the part is available and what it costs.. before i try to fix it..must be a bad gasket i guess..
    Oct 2009
    Richmond VA
    My bobcat was leaking from the gas guage, it was on the top of the tank. I took it out and cleaned it up, made a small rubber gasket out of an old intertube, put it back together. It has been fine so far. It would only leak when you filled it all the way up then drove the truck.
    You have to learn the rules of the game. And then you have to play better than anyone else.
    Albert Einstein
    Jan 2008
    your bobcat soundslike my ranger.. heavy rain today so its gonna wait ..
    Hello Everyone,
    I know this thread is old however I my ranger 8 is leaking around the fuel tank sending unit and It needs a new sending unit/pickup and I cant get the link to work or even find a replacement unit. does any one have any info? my code is 10535
    Thanks Tim
    May 2008
    Orange, TX
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
