Need help connecting a L14-30P for a 240 generator (pictures)
Results 1 to 23 of 23
    I need a little help connecting this up. I just bought a Hitachi E71 generator to run my Miller 180. I need to connect the 240 line and I am not sure how to rig it up.
    It is a L14 - 30P 240. This is what the Hitachi requires. Could someone walk me through the electrical connection? I would appreciate any help!
    here is the setup.....
    Jan 2006
    Re: Need help connecting a L14-30P for a 240 generator (pictures)
    you have one ground, one neutral, and two hots. If you have a volt meter, it is pretty easy. If you don't know how to determine the hots, neutral, and ground then you really don't need to be doing this by yourself.
    Quote Originally Posted by Scott Young View Post
    Well yes I have determined that. That is why I am asking for a little help, thus not "doing this by myself."
    No, I don't have a volt meter.
    Los Angeles
    Hold on a sec
    Got a Pic I think
    Before we get that far
    are you using Romex?
    You really need to get some Cord
    MM211 (Sold)
    Miller 125c Plasma 120v
    Los Angeles
    If you want to use the Romex to run the 180 temporarily... then use the Red & Black as the Hots and use the White as the Ground.
    BUT please buy some cord.
    on the L14-30
    X=Hot
    Y=Hot
    W= neutral which you don't use so do not terminate any wires to it.
    G=Ground.
    Good thing is you are wiring up a 240v device so even if you were to wire it 120v- not that big o' deal- welder just won't work
    Other way around and you let smoke out.
    Gotta go see if Santa ate the cookies yet
    MM211 (Sold)
    Northern Cal., Shasta County
    Basically on that 14-30 you're going to be using the two straights and the U shaped almost round. The round is the ground and the straights are the hots. The black and white will be hot and the (ahem bare) green you don't have will be the ground. Leave the 'L' lug unoccupied.
    Like Broc says you really should be using some kind of flexible cord material.
    Ooops, scuse me I see you have the twist lock. Use Brocs drawing and ignore the my above statement about the 'L'. lug
    The cord I have is the cord in the picture in the first post, the black, white, red and ground green, that is all I have to work with
    Los Angeles
    Quote Originally Posted by Down&out View Post
    Yes- but that is "Wire"- for behind the wall or in areas where it will not get banged up- for runs from the Electrical panel to a receptacle.
    Cord is what is on the Welder& Extension cords.
    Like I mentioned if you want to use the Romex wire you have temporarily you can but it is not the correct stuff.
    ...so use the Red, Black & White wires in the Romex you have in the Pic. Don't use the bare wire.
    I assume you have the Female 6-50r for your Welder to plug in to?
    MM211 (Sold)
    Here is my current set up. This wire I had laying around and I have been using it to plug into a 240 dryer outlet in my laundry room.. It is 50ft of Romex. I do need to switch to cord not doubt. But until that time I need to make do with this.
    Any help is greatly appreciated!!
    I do need to get some cord. SO, I suppose the questions is - what is the ideal setup for this combo -- Miller 180, Hitachi E71? I would like 50ft of cord. What is the best most affordable cord and where do I get it??
    Ca, USA
    You can buy 50' of 8-3 (8 gauge, 3 wire) SOOJ or SOOW 300 volt outdoor cord at Home Depot or Lowe's on the bulk reel, priced by the foot, for not all that much money. You can get away with less expensive 10 gauge if you're short on money.
    MM350P/Python/Q300
    MM175/Q300
    DialarcHF
    HTP MIG200
    PowCon300SM
    Hypertherm380
    ThermalArc185
    Purox oa
    F350CrewCab4x4
    LoadNGo utilitybed
    Bobcat250
    XMT304/Optima/Spoolmatic
    Suitcase12RC/Q300
    Suitcase8RC/Q400
    Passport/Q300
    Smith op
    Los Angeles
    Ok
    since you already have the 6-50 wired in which colored wires did you use?
    Just match them on the L14-30 Plug
    X=Hot
    Y=Hot
    W= Not used in this application.
    G= Ground
    10/3 cord is plenty for the MM180
    Some times it is cheaper to buy a 10/3 extension cord and change the Connectors rather than buying Cord by the foot.
    Home Depot has a Ridgid 10/3 cord with 5-15 ends- just cut them off and install the L14-30 and 6-50
    MM211 (Sold)
    Los Angeles
    Looks like you used the Black, white and Bare wire so
    Connect
    Black to X
    White- to Y**
    Bare wire -to G
    **THIS IS FOR THIS APPLICATION ONLY
    MM211 (Sold)
    Aug 2010
    Arkansas
    Rather than using romex I would suggest that you go to Lowe's or where ever and buy a 50amp electric range cord.
    Stephen
    Millermatic 251
    Miller Syncrowave 200
    Miller 30A Spoolgun
    Hypertherm Powermax 30
    Etc., etc., etc.............
    Cancer Sucks!
    Looks like it's time to get some decent extension cord for hell sakes.
    Thanks for the help. I am headed to the welding supply store to get fixed up.. any other suggestions for the setup I am using?
    Miller 180
    Hitachi E71 Generator 6000w continue / 7100w peak
    Los Angeles
    Miller 180
    They're open on Christmas? probably more $ than the Box stores.
    Seems like the price of those Ridgid 10/3 cords shot up in price
    MM211 (Sold)
    Shoot, I forgot today was Christmas. Well, monday then
    Shop rigs -
    Miller Syncrowave 250 DX
    Miller 252
    Home rigs -
    Esab Caddy c200i
    Metabo chop saw, grinders, etc
    Two cats
    Unhealthy addictions to surfing and demolition derby
    Los Angeles
    BTW- where are you located?
    MM211 (Sold)
    On the north coast of California near the Oregon border
    Shop rigs -
    Miller 252
    Home rigs -
    Esab Caddy c200i
    Two cats
    Los Angeles
    Quote Originally Posted by goinssr View Post
    Over Kill
    Range Cord will be 6g and at 50' $$$$ plus no need for 6g
    With the duty cycle of the MM180 one can actually use 12g Cord @ 50'
    MM211 (Sold)
    got my 50ft of cord and my pig tail. Could someone please let me know if I wired these correctly
    this is the pigtail wiring..
    L14-30 to 50A 125/250V Leviton (old clothes dryer male)
    Here is the pigtail
    Male
    female L14 - 30
    And here is my 50ft 10AWG 3 wire
    Male L14-30P
    and the female 650 for Miller, Esab ect..
    Shop rigs -
    Miller 252
    Home rigs -
    Esab Caddy c200i
    Two cats
    Los Angeles
    Good to go
    MM211 (Sold)
    Good to go
    Thanks Broccoli1!
    So on the 3ft pig tail the Female W on the L14-30 does not get a wire is that correct???
    And the same on the male of the 50ft cord the W stays open with no wire?
    Just the x and y brass get wires and the ground???
    I had one of the W hooked up with white on the pigtail for some strange reason..
    I thought it was wrong but I wanted to make sure
    Shop rigs -
    Miller 252
    Home rigs -
    Esab Caddy c200i
    Two cats
