Hypertherm Powermax 600 problems
Results 1 to 25 of 27
    Aug 2006
    South West, Florida
    Has anyone had a problem getting their 600 to fire. Mine is about two years old, has only about 4-6 hours use. Never had a problem with before. But now it won't even start cutting. Changed the consumables (tips, electrode) and all green lights but won't start cutting
    Good judgement comes from experience.
    Experience comes from bad judgement.
    Aug 2008
    Dansville NY
    Re: Hypertherm Powermax 600 problems
    Did you check that your ground clamp is secure on clean metal? And that your air is hooked up?
    Delaware
    Two things to check first remove the torch nozzle and tip push the electrode to see if it goes in and out free if the plunger is stuck it won't fire if thats ok then unplug the torch and check for any corrosion if there is any clean it and if you have some dielectric greese put it on the terminals then plug it in and out a few times then try to cut.
    Plasma Cutter and Welder Repair
    Tec.Mo. Wholesale Distributor and Dealer
    Consumables for the PT and IPT torch's.
    Aug 2006
    South West, Florida
    Specter, my torch in the past has always started regardless wether or not it was touching the metal to cut. I could just hold it up in the air and pulling the trigger would start the arc, it wouldn't stay on for more than a couple of seconds though, then shut off.
    Aug 2006
    South West, Florida
    Mechanic, I tried taking the connection to the machine from the torch, looked at it's fine. I took the handle apart to see if anything had come loose, and no problem their either. One thing I didn't mention is that in the past (one time). The internal pressure regulator started leaking air. I knew because you could hear air leaking from inside the unit. I opened the casing and found that there is hose that comes off the bottom of the bowl of the air regulator. It has a built in filter that is replacable, and a type of spring loaded relief valve at the bottom of the bowl. I took it apart and blew it out and it quit leaking. Well that happened again (the leaking from the air reg.). And I was doing some cuttin yesterday with it and it was cutting fine, even though it was leaking air. So tonight I did the ssame thing to the regulator and it fixed the air leakage. But no arc
    Piedmont, SD
    Hypertherm, and probably most other plasma cutters, are finicky about correct consumable installation. Go through the torch one more time and check by parts numbers as well as using the photo illustration on top of the case. I've been 'sure' I had everything in perfect order on mine a time or two before noticing I had some mismatched consumable somewhere in the assembly. Also, if you haven't done it already, unplug/disconnect the plasma cutter from your electrical supply for a good 5 minutes and try for a re-boot.
    Lincoln PrecisionTig 275
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Hossfeld bender & dies
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    21"Royersford Excelsior
    Two shops, still too many tools.
    Delaware
    Did you check the electrode plunger? it sounds like you have water or rust in the air valve or torch. when you pull the trigger does the air come on?
    Aug 2006
    South West, Florida
    I checked all the consumable part numbers made sure the plunger depresses easily. And still no arc oh and unplugged it for fifteen minutes. Air comes on when the amp dial isvturned down bit I believe that is normal. I have a large air drier on the unit. I would think it is something simple due to thelittle use it has seen.
    Delaware
    When you pull the trigger does the air come out of the torch tip/
    Aug 2006
    South West, Florida
    When I pull the trigger nothing happens
    Delaware
    Then when you had the cover off you must have unpluged or pulled out a wire from the air valve or the air valve is pluged and not letting air through. Take the cover off and check the wires to the air valves and check the filter to make sure air is getting through it. If you cant find anything PM me with your phone number and the best time to call you tomorrow evening.
    Oct 2007
    New Hampshire
    All good advice so far.
    It sounds like it may just be a simple wiring or broken wire issue.....you said the air flows when you turn the Amperage control fully counterclockwise (when you do this adjust the air flow regulator to about 65-70 psi)......but when you pull the trigger...nothing happens. This means the air solenoid and air flow circuitry is apparently working, but you are getting no signal from the torch trigger switch.
    I would suggest tracing the switch wires from the torch trigger to the connections back in the power supply. Could be a loose connection, broken wire, etc.
    Sounds like mechanic 416 is willing to help troubleshoot, or you can call Hypertherm tech service...they are free, and they are very good at helping find issues such as this. Here is their contact info:
    Technical Service
    technical.service@hypertherm.com
    800-643-9878 Tel - Toll Free in USA
    and Canada
    Good luck, and keep us posted.
    Jim Colt Hypertherm
    Delaware
    jtrapper maybe Jim is right you better call Hypertherm tech service...they are "free", and they are very good at helping find issues such as this
    Sorry I even tryed to help good luck and hope you get it fixed soon. George
    Feb 2009
    Melbourne, Australia
    What is it with your attitude towards Jim?
    You sound like you have a little sand in your v@gina.
    Oct 2007
    New Hampshire
    I cannot figure him out....he has some kind of an issue! I thought it was great that he was willing to help out the OP with his problem....I just offered advice on how to get to tech service and he acts pissed about it!
    Jim
    Aug 2006
    South West, Florida
    Thank you everybody for your help. My day job is now interfering with my ability to trouble shoot my problem. When I get it resolved I will post what the problem was. Thanks again, I think collectively you all have it narrowed down to the wiring betweeen the torch and machine.
    Aug 2006
    South West, Florida
    I was planning on my next post to follow after a call to Hypertherm to their technical dept.. but I didn't have to call them. Somehow it works, I really hate when things happen like that. Even though I was glad to see it works now. I'm not even going to speculate now. Trust me if I have anymore problems I'll be sure to follow up with you all. Thanks again everyone for all your advice.
    Victoria, BC
    So is it still working?
    I've got mine apart again trying to figure it out. Worked ok for a bit , then started to poop out. My issue is the arc either won't start or it will but will only gouge the metal( 1/8" flat) or won't start or gouge for a bit but it I pump the trigger or tap the tip it sometimes kick's over.
    And yes Jim, it's still the same problem as before. I'm being stubborn and just don't want to part with over $500 clams for the RT60!!!!! Especially since I don't know for sure if it's the torch!
    Oct 2007
    New Hampshire
    Sounds like a torch issue to me. The torch is not very complicated....you can download the service manual ( www.hypertherm.com click on download library, choose powermax600, choose manuals, then service manual) and it will show an exploded view of the torch assembly. You can repair or replace components as needed in the torch head if you don't want to buy a whole new torch. It will be worth more to you if it works!
    Also....tech service at Hypertherm is very helpful...and free.
    Technical Service
    and Canada
    Jim Colt
    Quote Originally Posted by bert the welder View Post
    Jan 2011
    Australia
    Quote Originally Posted by LarryO View Post
    I like that one Larry, may have to borrow it......
    Samson 510 CNC plasma table
    Hypertherm 85
    Plus a shed full of cheap arsed crap.
    Victoria, BC
    Thanks Jim! Hadn't seen that section on the website before. I'll print it off and get a friend to go over everything with a circuit tester and see if we come up with the issue.
    Thanks again!!!!!
    B
    Technical Service
    and Canada
    Jim Colt
    Oct 2007
    New Hampshire
    Often problems in the torch are pretty simple......although if internal parts are badly arced or burned...it may not be easily repairable. Still...it is usually cheaper to repair that buy a whole new one!
    The new RT60 torch is a much nicer torch...better cuts, longer consumable life.
    Jim
    Ceres, California
    Try taking some pictures of the last set of consumables, Up inside the torch head.
    Care fully remove the handle and take a picture of the switch and back side of the head.
    Post the picture here.
    Victoria, BC
    Good thinkin'!
    Ceres, California
    Another thought, if the torch fires but will not cut. First check the ground, If that's good unscrew the cap 1/8 to 1/4 turn. Seen this a bunch of times. according to hypertherm it has something to do with the distance from the electrode to the nozzle. With all the older torches you always tighten the cap until it stops then back it off 1/8 to 1/4 turn. The brand new model torch has a hard stop that fixes this issue.
