Gas Conversion Kit- 125 Handler
Results 1 to 11 of 11
    Jan 2009
    Mountain Home, AR
    Anybody know the best place to get a conversion kit so I can use Gas with my Hobart Handler 125? Also, can you sum up the pros and cons of using gas?
    Thanks!
    Hobart 125
    Words mean things
    Jan 2011
    Re: Gas Conversion Kit- 125 Handler
    You can find one at www.fleetfarm.com for around 80.00 . Them you will need a gas bottle, if you buy the small ones, get 2 because if you don't it will run out at the worst possible time.I use the 80 cu. ft. bottle.
    Oct 2005
    Waco, Texas
    I have seen the Hobart MIG Gas kit at Tractor Supply and Atwood's. Both places were about $100.00
    Jan 2009
    i think i pd like 70 at fleet farm and it was easy to wire in coupla plugs and your in biz ness. i bought my bottle at valley nat gas ,it was like 80 buks and 1st fill free and its like 35 for 75/25.
    miller maxstar 150 hobart handler 210 w mig conversion hobart 250 arc force plasma cutter boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
    Charlotte NC
    thanks for the flletfarm link, definately alot cheaper than Northern, gonna have to order on eof those
    Sep 2006
    Ann Arbor, MI
    Late to the party, but grizzly has it for less...
    http://www.grizzly.com/outlet/Mig-Co...5-H6566-/H6567
    Hobart Handler 140
    Everlast PowerMTS 200S
    Hypertherm Powermax30
    May 2007
    Looking at the grizzly site their picture seems wrong. Unless they're only sending you the inner tube for the gun? A bit weird..
    Hobart Handler 125 #500495
    Miller Diversion 165 #907005 (tig learning box)
    May 2007
    Even more late to the party, as I'm searching through, here's what I found on the Hobart forum:
    http://www.hobartwelders.com/weldtal...98&postcount=4
    Since the Hobart 125 already has an internal gas valve, thus all you need:
    To weld with shielding gas with this model, the user must change the output polarity and supply the shielding gas and regulator
    May 2007
    PS for anyone buying the kit from the Grizzly website, here's a $10 off coupon code:
    11YELP$10
    May 2007
    Contacted Grizzly and they confirmed that the $60 they're selling is the exact same that Hobart is selling -
    I ended up purchasing this kit as most of the spare parts would've cost me just as much separately.
    May 2011
    Worcester, MA
    There are NO disadvantages to using gas other than lugging a tank around if you need to take it on the road.
    That machine will be a real joy to use once you start using gas.
    Cleaner / prettier welds, better puddle control, no slag to bang off.......
    You'll see!
    Just keep your flow down to about 20-25 cfm. Any more than that is a waste and will create turbulence sucking air into your arc and causing porosity.
    Good luck!
    Measure twice, cut once.
    Millermatic 211
    Millermatic 251
    Miller Dynasty 200DX
    ESAB O/A Set-up
