cheap welding table
Results 1 to 25 of 27
    Jan 2011
    Evansville Indiana
    cheap welding table
    I was going to build a small 2 x 2 ft table but the metal supplier had a 2' x 4' x 1/4 " plate for 25 dollars so I decided it would be a bettter size and cheaper than if they cut it. I used an old bed frame for legs welded directly to the bottom of the diamonds on the bottom side. The shelf braces are the bed frame cross bar ends. To keep it from bowing in the middle I used 2 three foot pieces of scrap 3/4" black iron pipe to keep it straight. The wheels were from Harbor Freight 2 swivel locking and 2 straight.
    Jun 2010
    canada EH!
    Re: cheap welding table
    pics?
    _______________________
    OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
    Jan 2011
    Evansville Indiana
    Quote Originally Posted by trouble007 View Post
    pics?
    If I can figure out to post them
    Jan 2011
    Evansville Indiana
    pics?
    That is a plasma cutter on the bottom shelf. Airforce 250
    Jan 2011
    Evansville Indiana
    Re: cheap chopsaw table
    I also built a cheap table with locking wheels (Harbor Freight) for my chop saw. Legs from bed frame and left over 3/4"plywood for top and scrap 1/2" plywood for shelf. DeWalt chop saw not from Harbor Freight. (Go figure).
    Jan 2011
    Evansville Indiana
    Cheap chop saw table
    Aug 2008
    Dansville NY
    Just don't bang on your work table too hard or it might bend or collapse
    Apr 2009
    La / Ga
    For light work it looks like a great table , at a great price .
    Aug 2004
    North Central Indiana
    Your projects came out good, nice work.
    Apr 2010
    North Carolina
    You could have used that plasma cutter to cut the plate into two pieces and welded them together for a 2'x2'x1/2" (your original size) table. Just an idea! Looks good though.
    Aug 2008
    Good work! I love re-purposing old bed frames! I'm making a cart with one right now...
    Mark
    Hammerhead Racing
    Edgewater Fl.
    www.hammerhead1320.com
    Dec 2009
    Great score on the 1/4 steel plate and the table looks good
    I like it when I see quality things built with recycles.
    Jan 2011
    Evansville Indiana
    Now that I'm done I think the 2 x 4 is better. The longer table is more stable and strong enough for my small projects. It's good for more than welding, like cutting wood or working on other stuff
    Jan 2011
    Evansville Indiana
    It's stronger that you think. If I'm working on anything too heavy I wouldn't be able to get it up on the table. So far it has worked out perfectly for my small projects, like a frame for my chop saw table and a brace for welding bottles on a very small dolly for very small tanks.
    May 2008
    Fraser Valley, B.C. Canada
    Working as a professional fabricator, I prefer 3/4 or 1" but, if you are a hobbyist welder that is not going to put much heat to the table or welding and pounding the crap out of something, the table should hold up fine. Its great for welding smaller projects on.
    Im currently working on a project for a customer which needs a chipper guard for a local mill. The tolerance on the base is +/- 1/16. So for something like that, a level table is a must.
    Hope your table works out for ya! I hopefully will get a 1/2 plate for my table at home from work soon.
    Jan 2011
    Evansville Indiana
    I kinda like the size as is and it's heavy duty enough for my small projects. If I have a large or heavy peice I will work on it on the floor. I did round the corners with the plasma cutter.
    May 2009
    Columbus, OH
    Watch out for fires with the wooden one. Nice work!
    Texas
    I think 1/4 is fine.
    That is what I am gonna use with a good frame under it. I'm just a hobby welder and I don't plan on putting a dozer on it. Mine is going to be 4foot X 9foot so I can roll 4 wheelers, riding lawnmowers etc. Also because the 4 x 9 frame was already made. Just needed a top and legs.
    One day I'll makeone with at least a 1/2 inch top.
    We are on our way to being farmers! Our site is always under construction so check back often for updates.
    http://www.philosophyfarmstyle.com/
    Jul 2010
    Austin, TX
    Quote Originally Posted by JRobAcker View Post
    What do ya think of that plasma cutter? I'm on the fence of buying one.
    Jan 2011
    Evansville Indiana
    This model will cut up 1/4" steel, also cuts aluminim & brass. It has a built in air compressor. The larger models don't, you have to supply your own air supply. For most moderate stuff it does a great job. I don't know why plasma cutters cost so much??. It does run on 120 volts and with it's own air it makes it super portable.
    table looks like a good solution for you
    Not to hijack but about the plasma cutter, it's fine for sheetmetal, they say it will cut 1/4" , it will, BARELY. I bought one and returned it the same day , I bought a Hypertherm Powermax 30 and love it. I want a bigger one now though...lol
    Jan 2011
    Evansville Indiana
    I bought this plasma cutter about 6 years ago or so, knowing what I know now I could have gotten one twice the power for half the price. I do have an air compressor and 230 voltage, but you learn by doing. Also bed frames are tougher than you think, just try cutting one with a hacksaw.
    Feb 2012
    Sparks, NV
    Why would you use a hacksaw when you have that nice DeWalt chop saw Or plasma?
    Actually I like using a hack saw Hows the bed frame holding? Kids do alot of jumping on beds , never seen one break. I do try to design the load into the frame instead of weld when I used a bed frame tho. Same as you did. I made a plasma torch cart with bed frame.
    _____Gauntlets_____
    ____Genesis 4:22___
    Dec 2016
    Ventura County, CA.
    I like it! Bedframes used to be plentiful "alley finds" except now the roving metal collection trucks seem to get them all... great when you have to throw something away, not great when you need metal!
    If you want to learn no one can stop you.
    Hobart Handler 175 / AHP AlphaTig 200X V4 / HF 95136 Plasma
    Apr 2016
    CA
    Nice use of scrap bed frame materials Rob. I have been stockpiling up bedframes for about a year now. I try to stop every time I see one and toss it in the back. I missed out on a weight bench a few weeks ago made out of 2"x2" thin wall tube. I plan on using weight bench tube materials to frame my welding table when ever i get around to it. I think one more weight bench and i will have enough materials to build a welding table frame.
    '65 Lincoln Idealarc 250 AC/DC
    L-tec PCM-VPi 40A plasma
    ESAB REBEL EMP 215ic
    ESAB Mig Master 250
    Victor Performer O/A
