Adapter plug for 240 volt generator?
Results 1 to 24 of 24
    Feb 2011
    Hello everyone,
    I recently bought a Miller 180 welder in California, knowing that I have a portable generator with 30-amp, 240-volt capacity at home outside Tucson (we live completely off the grid on solar and wind power).
    To my chagrin, I just discovered that the welder has a three-prong plug, and the generator's 120/240-volt outlet takes a round four-prong twist-lock male plug. Ack.
    Does anyone know if there is a suitable adapter available so I can use this generator?
    I hoped my first question here would be about welding - but until I can actually start the thing I'm stuck!
    Thanks for any advice.
    Apr 2008
    Yuma AZ
    Re: Adapter plug for 240 volt generator?
    Make one would be just as easy. Buy the plug that fits the generator, a short bit of cord & an outlet that fits the welder. Or you could add some length to the cord to extend the "noise" away from the welder a bit.
    Should be able to find the plugs, outlets & cord at Home Depot, Lowes or places like that.
    Mark
    Craftsman 12"x36" Lathe
    Enco G-30B Mill
    Hobart Handler 175
    Lincoln WeldandPower 225 AC/DC G-7 CV/CC
    Add a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG
    PapaLion's Gate Build
    May 2008
    Fraser Valley, B.C. Canada
    Quote Originally Posted by MarkBall2 View Post
    I totally agree. I did a small job for a friend and had to do the same. I bought the round style plug and a female welder adapter plug. I wired the two together as I did not want to wire the round style plug to my welder cord directly.
    I also have another cord wired for a dryer outlet. Attachments always come in handy.
    Feb 2011
    Thank you both. I'll head into town tomorrow and look for the materials. I'll need to figure out which wire is which - or are they likely to be color-coded?
    Apr 2008
    Yuma AZ
    Usually 2 wires are 110 volts, 1 wire is neutral. Check with a multimeter for 110 volts to neutral, then 110 volts to neutral. Then remember the colors of the wires (if you can see them) entering the plug. On the adapter, you just have to keep the neutral the same. It won't matter too much which side of the other two pins get 110 volts, as long as both do & the neutral isn't crossed.
    Mark
    Enco G-30B Mill
    Hobart Handler 175
    Feb 2011
    Thank you!
    May 2008
    The colors should match. "Should". The one I bought came with a wiring diagram but I don't know where that went. There should be info on the net as well. Depending on the welder and plug, you may only need to hook up 3 of the wires.
    Feb 2011
    Thank you. I'm pretty sure that one of the connections on the four-prong 120/240-volt twistlock outlet on the generator will be a ground, so I assume I won't need that one - just the two live feeds and the neutral?
    Jun 2010
    canada EH!
    other way around you will need the 2 live feeds and the ground. neutral should be taped up out of the way.
    Hope this helps
    Ryan
    _______________________
    OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
    Mar 2009
    Iowa
    Just get a three wire cord. Then you don't even have to tape the neutral. Cheaper too. Two hots and a ground.
    My name's not Jim....
    Jan 2011
    Coronado. CA across the bay from San Diego, CA
    I will not disagree about using a three wire cord to make up a cable with a trhee prong socket and a four prong plug.
    If your welder needs a neutral for 120 volt controls, fans etc, you will need to have a neutral.
    I offer three choices: Good, Fast, & Cheap. You may pick two.
    Hobart AC/DC StikMate LX
    Harbor Freight AD Hood
    Harbor Freight Industrial Chop Saw
    DeVilbis 20 Gallon, 5 HP Compressor
    Feb 2011
    Thanks to all again.
    I'm assuming from the fact that the welder has a three-prong 240-volt plug that it does not need a neutral, just the two hots and ground.
    Northern Cal., Shasta County
    Quote Originally Posted by JMHAZ View Post
    Correct.
    Los Angeles
    There ya go
    MM211 (Sold)
    Miller 125c Plasma 120v
    Apr 2009
    Springfield, Ma
    There ya go
    I like to mark the white wire with red or black as a reminder that it is NOT a neutral in this application sorry, I know I'm a fussbudget the electrons don't care
    There is so much confusion over neutral vs ground GREEN is ground and WHITE is neutral GREEN does NOT carry current (except under fault conditions, WHITE DOES carry current under normal conditions. Under the wrong conditions it will bite you if you get it wrong !!!
    (sorry for the rant)
    -- fred
    Feb 2011
    Success:
    Thanks for the advice, everyone!
    I love the diagram, I've ran in the same problem in the past and I didn't know which was which ,so I just rented the right tools.
    CHEERS! this is amazing.
    Quote Originally Posted by lineboring.org View Post
    i finally got what i'm looking around, thk guys.. CHEER'S!
    I just wanted to give kudos for this awesome thread on my first post. I am brand new to welding, and bought my first tig welder. I have been trying to figure this out but have been scared chitless I would destroy my $1,000 plus generator or my $1,000 tig welder.
    Either is a bad outcome, but the image posted is absolutely perfect, and I can't thank you enough for it!
    One question. In the picture you show using a receptacle. Can I simply use a 3 prong female plug attachment instead of a receptacle? What purpose (if any) does the receptacle serve?
    Los Angeles
    Quote Originally Posted by chicagogunsmith View Post
    You can use a Plug most Box stores do not carry the 6-50 Female connector/plug.
    They do carry Twist lock style connectors and such but not the 6-50
    You can find them on line though
    http://www.amazon.com/Hobart-770204-...ref=pd_cp_hi_0
    MM211 (Sold)
    I had a 3 wire laying around from an extension cord for an old Leister Hot Air welder. I went to home cheapo and got the plugs and connected as per your diagram. Tested my Everlast TIG last night on my Generac generator and all is well. Well, I didn't check the shield gas as I have to get that tomorrow. FWIW I checked to make sure the generac runs clean, and wouldn't harm my TIG.
    I ended up getting 250v 30amp plugs
    L14-30p male to connect to generator
    L6-30R at end of extension cord
    L6-30P for the end of the welder which came with no plug.
    Dec 2011
    Houston
    Success:
    I just saw this post, reference 240 adapter plug for a generator. Since its been awhile how has this set up worked for you?
    Setup worked for me as I described above. After an hour of welding I am deaf though, even with a 50' extension cord. I'm having 220 wired into my garage this weekend.
