welding up a bellhousing
Results 1 to 20 of 20
    Oct 2010
    western kentucky
    friend of mine brought me a th-400 transmission to weld up.. bellhousing is cracked... what would be a good filler rod to use?
    like 4045?
    Mar 2008
    Greater Seattle, WA
    Re: welding up a bellhousing
    Without really knowing specifically what alloy a TH400 is, I would say go with 4043 (consisting of about 5% silicon), because cast aluminum usually has silicon in it so that would be the best match. 4047 (with about 12% silicon) I've heard good things about using for welding dirty cast, but it is much harder to locate than 4043. 4047 is sometimes sold as a brazing rod I've noticed. It has a lower melting temp but is also a "fast freeze" rod (a eutectic mixture of silicon in aluminum.) Only a 10 deg F difference between liquidus and solidus temp.
    To prep, make sure to clean the grease and oils out as best you can and scrub all the oxides off the surface in the area you are welding. A "bake" of the area to be welded with a torch until oils in the metal are smoking would also be good. Vee out the cracked areas and fill the gap to ensure penetration. I would go with about a 45 degree or so bevel so and get your tungsten down in there deep, to get a puddle started deep into the bottom of the vee. Expect a little distortion (contraction of the weld bead) from the weld. If you get any stubborn dirty nasty spots, let the work cool, grind out all the dirt and materials surrounding any inclusions to root them out (carbide burr on a die grinder works great for this), then redeposit fresh filler rod in place. If you can access both sides of a crack, weld both sides.
    If memory serves you have a TA185, correct? I'd go heavy on the EN balance % and hit it with all 185 amps you've got to minimize the heat input into the rest of the transmission. Assuming the bellhousing is relatively thick stuff. Some pre-heating with an air-propane torch may be helpful if the area to be welded is particularly thick.
    May 2008
    Orange, TX
    Brake-Kleen works good to get the oils out of the crack(s) as well. Spray - blow dry, spray - blow dry, repeat as needed until there's no more oil/grim rising to the surface. Grind out and repeat.
    It also helps identify the end of the crack(s) as does the heat that jakeru mentioned but don't heat the Brake-Kleen for the reasons stated in past threads regarding the dangerous fumes from burning liquid forms of brake cleaner products.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Apr 2010
    Galesburg, il USA
    My neighbor gets these from dealers and shops all over, and in my thinking does them a bit wierd.
    He doesn't spend much time cleaning, maybe some wiping of oil and grinding the crack. When he welds it's very hot and often he'll shove a ton of rod in the puddle sagging it to the other side (I mean a real blob here).
    After finishing one side he cleans (cuts/grinds off) any mess from melt through and lightly grinds the other side and welds a reinforcing bead on the backside.
    It's hard to argue about how he does it as it goes pretty quick and folks keep bringing more housings when they bust them. He does much the same when pieces are broken off, so I'm thinking he just sees the junk comming up and sags it through to get rid of it.
    Must be that practice, practice, practice thing... it just looks wierd.
    Matt
    Oct 2007
    Yuba City, CA
    brake cleaner on porous castings
    1-Duane, you're presuming that the air blow off will positively remove all
    the brake cleaner, including that which is mixed with the crud and grime--remaining after blow off and whatever may find it's way into casting pores and on the opposite side of the break.
    This is somewhat dicey to do--hopefully if one's doing the brake clean route
    (which has been repeatedly flagged with stickies--as a potentially disabling
    to fatal method).....then 'hopefully' they'll recognize that particular smelll of
    liberated chlorine compounds--which can eat their lungs, before it eats their lungs.
    Fooling around with brake cleaner as above is a dangerous thing to do.
    Yes--you do it and get away with it---I won't.
    **I have relatively little experience actually welding aluminum bell housings,
    only having done over 241 in the last 23 years--below is what works for me:
    2-TH is turbo 400 trans. The older trans. have less casting porosity than the newer ones---which can exhibit amazing porosity--more than 50%.
    -4043 works good.
    -I use lacquer thinner, water cleaners
    -Groove prep breaks with carbide burrs, some grinding
    -on inverter machines--running full unbalanced--like 10% EN,
    with sharp point on ceriated, thoriated, lanthium tungsten--produces
    a tight, focused arc with max. heat input.
    -running min. AC freq. CPS adds to max heat input
    -Many of the 'experts' on this site-don't understand/have never used
    focused AC--on decent inverters.
    -focused max. heat will do much more, easily, quicker than screwing around
    with cleaning action on AC. To repeat-focused heat works where all other methods-fail.
    -in contaminated and porous castings--it can become an exaggerated form of 'bump-welding', jamming the rod in under the crust. Tack up, weld one side, then back groove and weld the other side.
    --bell housings by their shape are a restrained casting, which can further crack
    or distort from the heat of welding. Using intermittent water spray cooling with air blow off helps.
    --after repair, the bell housing flange faces need to be in same plane--via temporary bracing/clamping/inspecting with straight edge. Some prior inspection and repair planning helps.
    -most breaks on the flanges are caused by incompetent assembly attempts,
    not having the trans./input shaft lined up properly, then attempting to 'draw the
    trans. up tight to the block, by tightening a nut/bolt. The perpetrator needs to understand that this is what breaks things, big time.
    Blackbird
    Guerneville Ca
    Would really have to see the bell housing and where and how it is cracked.
    May need to bolt it up to a steel engine block to keep it from warping and then recheck after welding.
    It should be tacked and welded on the inside FIRST then welded on the OUTSIDE LAST.
    Many considerations.
    I would preheat a weldment that large and that thick before TIG welding..
    If it is for racing I would not weld it at all.
    Aluminum is in the as welded state is 64 % strength of the parent metal.
    For street use it is ok.
    AWS certified welder
    b.c. canada
    4043 is what i use to tig alu cast stay away from brake clean just not worth the risk
    -clean clean clean and clean again stainless brush and acetone works best for me
    -Use carbide not a grinding disc as the disc will just contaminate your weld again
    ( i use a skill saw to groove with a die grinder works just as good but takes longer)
    -use a something as a jig to hold everything in place
    -weld it up on one side then groove other side weld it then cut out the weld and do it again
    -and if you want a nice finish wash the casting bubbles out with the tig
    cheers and hope this helps
    May 2008
    Orange, TX
    Quote Originally Posted by dave powelson View Post
    1-Duane, you're presuming that the air blow off will positively remove all the brake cleaner, including that which is mixed with the crud and grime--remaining after blow off and whatever may find it's way into casting pores and on the opposite side of the break.
    Fully aware of the stickies with all the warnings Dave and with all due respect, the chances of getting hit and killed by a drunk/sleepy driver are much greater but I don't intend to stop driving. Never said there wasn't a risk but rather indicated to use necessary caution. If one deems that level of caution is to not use it, so be it.
    Quote Originally Posted by abec View Post
    Ever read the MSDS for acetone?
    It boils down to treating all chemicals with the proper respect they require and exercise the necessary caution when/if using them. I routinely work in areas where H2S and HF releases could happen - both which can kill you quickly - but it doesn't stop me from taking the proper steps to protect myself (which are required to be able to work around them anyhow) and go about my work.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Mar 2009
    Iowa
    Duane
    I use brake cleaner frequently. Lot's of it. I don't have any problems welding with the non-chlorinated stuff. Still burns my eyes a bit after the heater burns the fumes, but as far as welding goes......no problems. Spray paint fumes run through the heater burn too. I just open the overhead door frequently to swap out the air.
    My name's not Jim....
    Feb 2006
    Quote Originally Posted by Matt_Maguire View Post
    Matt
    He has gotten used to the porosity and it's shortcomings. I have done some engine case covers and a bell housing, they were a big headache when trying to be nice with them. What I found that worked best for my welder was to grind the crack, and drill the ends to stop the crack. Clean them with acetone and a scrub brush. Set the machine with a low frequency. I found the high frequency with cast material leads to a lot of cracks around the weld, and a LOT of cracked welds with 4043 filler. On the other hand, adding a lot of filler with the frequency about 65-70 was OK, and it did not crack the housing any more. I still like the 5356 filler more than the 4043. I saw too many cracks in the 4043 for my liking. It was primarily from weld shrinkage, it was easy to see how the cracks formed.
    But yeah, grind off the sag on the inside, and put a decent bead in there. You will see a LOT of opening up as you get the puddle going. Amazing how much lost open space there is in cast aluminum!
    Jan 2006
    In A Nice Comfy Chair
    5356 is your best bet in this situation..
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Sep 2010
    Brooklyn NY
    hmm, I have an idea of eventually replacing my tranny with a awd stick tranny & this will require me having to cut a bell housing in half & then weld that to the replacement tranny. the replacement tranny does not use a separate bell housing at all, it's all cast into the main tranny case but I want to cut the front off & then weld the front on from a different bell housing. I'm going to be making somewhere in the neighborhood of 600hp, does this sound like it's doable?
    miller 330a bp TIG
    miller dynasty 200DX TIG
    millermatic 185 MIG
    thermal dynamics cutmaster 101 plasma cutter
    snap-on YA5550 plasma cutter
    hypertherm powermax 30 plasma cutter
    baileigh CS225 cold saw
    etc....
    b.c. canada
    yup hell of alot less scarey then brake kleen
    Feb 2010
    Northern MN
    Quote Originally Posted by turbocad6 View Post
    I would do it and just try to weld some webbing and gussets on the housing. Making the joint jagged instead of straight will also help by giving it more surface area and a non linear joint will be less prone to shearing
    May 2008
    Orange, TX
    My point is all chemicals require proper use and precautions. Never said or meant to imply it was worse than brake cleaners.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jan 2010
    Mesa, AZ
    I have found that once they crack they typically will crack again so I am using this now. They have them so you can but GM behind a mopar or Ford as well.
    NEW JW Ultra Bell Bellhousing Turbo 400 to GM
    http://www.plunderhere.com/auction_d...ion_id=2310998
    Please dont mistake my enthusiasm for talent!
    Feb 2011
    Martinez CA
    Be very careful using BRAKE KLEEN to clean grease before welding it has a chemical in it that when heated can cause VERY SERIOUS lung kidney and liver damage over night death has been documented.....Use lacquer thinner or denatured alcohol to clean your aluminum before welding........
    http://forums.vintage-mustang.com/vi...ng-hazard.html
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    don't cut the tranny, make an adapter plate.
    Feb 2011
    Martinez CA
    I have welded TH-400 tranny's before and the weld will depend on how clean the casting is....4043 is typically what you use on most cast aluminum any dirt in the casting will show up as a porosity in the weld and not be as strong as possible if it
    was clean......Does that make sense? Anyway welding should be your LAST option
    in my opinion....
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    Feb 2011
    Martinez CA
    ...zap!
    Yo Zap did you get my PM about not being able to send PMs?
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
