Lincoln magnum chiller
Results 1 to 8 of 8
    Feb 2011
    Martinez CA
    I check my welder for dust and the cooler for water level alot.......Probably just a habit I acquired through the years but I guess it's a good habit.....Well I noticed a "Squeak" noise coming from the cooler and I had some time so I took the cover off this morning and found that the nylon fan had lost it's fit on the motor shaft and was slipping (Not turning) I took the motor out of the cooler frame and saw that the motor shaft had a flat spot on it for like a set screw ? evidently the fan is glued on from the factory with a small clamp that holds the fan on the shaft along with the glue I cleaned everything up and mixed up some JB Weld and glued the fan back on.....
    Must have worked because the squeak went away..... weird
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    May 2010
    Port Orchard, WA.
    Re: Lincoln magnum chiller
    Quote Originally Posted by B_C View Post
    Blasphemy!
    With your Tig skills, why didn't you just weld it?
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Feb 2011
    Martinez CA
    Well plastic doesn't weld real good............
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
    Aug 2008
    Canada with mosquitoes.
    J B welds win's again "LOL"
    Vin.
    Jun 2008
    Central California
    The nylon might have originally had a molded hump inside the hole to match the flat. Lots of modern small 'plastic' fans have just a spring band on the hub to create enough friction to keep it tight on the shaft; some have both that and the lump. Sometimes when epoxy wont stick to plastics, first coating the plastic with cyanoacrlate (e.g. superglue or equivalent) will allow better adhesion.
    Feb 2006
    You can use 309 for SS to carbon steel.
    But I don't think it's gonna work for carbon to plastic........
    Just spent $600 on a new cooler today, finally got tired of burning up small pumps.
    Feb 2011
    Martinez CA
    Quote Originally Posted by Oldiron2 View Post
    I figure if I start hearing the squeak again I'll go with super glue....
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
