Tr-300-hf
Results 1 to 15 of 15
Thread: Tr-300-hf
    Ceres, California
    Tr-300-hf
    Does anybody and a parts manual for a TR-300-HF spec number 6496-1.?
    I need the part number for the spider in side the polarity switch.
    I might still be able to get them but thermal arc will not look up part numbers for these welders. They will sell you the part if you have the number and its on their shelf.
    Apr 2011
    VA
    Re: Tr-300-hf
    I might be able to hook you up. We sold a TR-300-HF recently, and the manuals went with the machine. The purchaser is willing to let me make a copy. If I get it, I'll PM you to figure out how to get it to you. In the meantime, the part number you're looking for might be 2008251. Make sure to look at it before you buy, in case that's not the right number.
    Jan 2006
    In A Nice Comfy Chair
    Re: Tr-300-hf
    I may have just what you need..
    I'll post a pic of it later today..
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Jan 2006
    Re: Tr-300-hf
    After some searching I found a pic of the switch..
    It's out of a AR250HF but I think they are all the same..
    Look familiar..?
    I have the spider out of that one in the pic..
    But I also have the whole new switch so let me know..
    ...zap!
    Do not attempt.
    Ceres, California
    Re: Tr-300-hf
    Here is a picture. If you zoom in on the center you can see the hub that is broken.
    The top one is the polarity switch.
    Zap PM sent
    Jan 2006
    Re: Tr-300-hf
    Yours looks like it did the same thing mine did..
    The (I call them calipers) look like they melted and stuck to the spider where they were and when you went to change the polarity the switch broke from the force..
    I really think you need the whole switch rather than just the spider but the switch I have has new calipers in it and was working fine until the Hi Freq went south..
    Name:  Spider and Switch.jpg
    Either or they are yours.
    Call me..PM sent..
    ...zap!
    Do not attempt.
    Apr 2011
    VA
    Re: Tr-300-hf
    The guy that bought the TR-300-HF that we sold (because the high freq went out) rebuilt the high freq panel using parts he cannibalized from an old add-on high freq box he had laying around. He says it welds as good as ever!
    Ceres, California
    Re: Tr-300-hf
    Worked on a lot of these switches. The grease gets hard and the owners never move them. Then one day they try and snap they break the spider. In the past is was easy. order in a spider, clean out the old grease and regrease with electrical grease and assemble.
    Fixed a lot of them that were just stuck and had not been broken yet.
    Hobart used this style switch in a lot of welders.
    Apr 2011
    VA
    Re: Tr-300-hf
    I have the manual in-hand. I need to figure out if I can scan it into a .pdf, or if I will need to make a hard copy. Might take a couple more days to sort this out, but I'll let you know...
    Apr 2011
    VA
    Re: Tr-300-hf
    BTW...the part number for the switch as listed in the book is 200825-1, or 200825-2. Our computer system omits dashes in part numbers. The book says that the range switch and selector switch are the same, but I suspect you already knew that...
    Apr 2011
    VA
    Re: Tr-300-hf
    PM sent
    Ceres, California
    Re: Tr-300-hf
    Received the manual. Got the part number for the spider (hub) and thermal arc has them is stock. price is around $44. Soon as I get the new hubs I will disassemble both switches.
    Clean them up and assemble them. I will take pictures of the different steps and post them.
    Ceres, California
    Re: Tr-300-hf
    First picture is a side view of both polarity and range switches. Each is two switch segments bolted together. The next series of pictures show the switch coming apart. The broken hub.
    All 4 segments had to be disassembled, cleaned and regreased with electrical grease.
    The grease found in these switches was found to be dry and hard. That is way they would not move and the hub broke. I caught the range switch just in time. as one contact had just started arcing. I was able to polish it up and save it. Assembled the switch group and made sure it worked smoothly.
    Re: Tr-300-hf
    Ha! Just what I was looking for. Thanks for answering before asked!
    Re: Tr-300-hf
    Hi there.
    would you be able to email me a copy of the manual. email is gemsquashthg@gmail.com
    much appreciated
    tim.
