Just welded my exhaust with an arc welder...
Results 1 to 19 of 19
    should have thought to get on this forum first and ask but, is it ok to use flux welding on something like this?? Had to do about 7 or 8 welds, first time welding.
    Jan 2011
    Central Texas
    Re: Just welded my exhaust with an arc welder...
    That sure seems like the hard way to do it... .. when I have done it or seen it done at muffle shops they use oxy - acet torch... sure easy to burn through some things... often times you are connecting to partly rusted pipe which will burn through very easily....Even clean new pipe seems like it would be hard to reach the top side with a stick...
    Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.
    WW2 era Miller TIG.
    Quote Originally Posted by GBM View Post
    Sorry I guess I worded the questions wrong, I meant is it safe to do it like this? Do oxy welds use flux? I ask cause lead is obviously poisonous.
    Jan 2011
    Central Texas
    Oxy-acet welding on steel does not use flux....
    Not sure what you are referring to about the lead .... you mean carbon monoxide poisoning with reference to not having any leaks in the weld ?
    WW2 era Miller TIG.
    Well ****, would've got an oxy torch in that case, I hate lead, I mean the residual lead dust in the pipe and in the welds that will come out as it runs.
    Jan 2011
    Central Texas
    An oxy - acet rig is so useful for things which an arc welder can not do.... I don't know how anyone gets along with one....
    WW2 era Miller TIG.
    May 2010
    Sparks, NV
    just don't ever clean metal with brake cleaner before welding. brake cleaner+ extreme heat= Phosegene Gas= Death... as little as 6 parts per million!!!
    what type of exhaust? car, motorcycle? you will want to use a low penetration and small diameter rod if arc welding...
    AHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; ESAB 875 plasma;Evo 355. OA
    Jan 2011
    Coronado. CA across the bay from San Diego, CA
    If you just welded your exhaust system with a stick machine and it works without burning through the pipe, you must be doing something right; maybe the hard way, but if it works; it dosen't seem wrong.
    I have not been in a working muffler shop for a lot of years; back in the day the shops all welded every thing with an oxygen / acetylene torch. Nobody working in a muffler shop was skilled enough to sucessfully arc weld mufflers and pipes.
    I offer three choices: Good, Fast, & Cheap. You may pick two.
    Hobart AC/DC StikMate LX
    Harbor Freight AD Hood
    Harbor Freight Industrial Chop Saw
    DeVilbis 20 Gallon, 5 HP Compressor
    Apr 2007
    Prunedale, Ca
    Lead? Unless your running leaded race fuel I dont think you have anything to worry about, even then I never through twice about welding race car exhuast that we run leaded fuel through.
    HTP Invertig 201
    Lincoln Idealarc SP250
    Miller 180 AC Stick
    By farmall:
    They should have held the seagull closer to the work, squeezing evenly for best deposition.
    Feb 2008
    North of Philly
    Quote Originally Posted by fordman View Post
    Interesting. I know leaded gas was still used in the late 90's for aircraft fuel. I didn't know race fuel was still leaded. I'm guessing the OP is from a counrty that didn't stop using leaded gas in the 70's.
    Ronald Reagan
    Feb 2010
    Goochland, Va.
    I suspect you are confusing soldering with welding - lead based solder might be what you are thinking. OA fusion welding on steel does not use solder or flux.
    Hobart LX235
    Victor 250 Oxy-Acetylene Rig (welding and cutting)
    Bobcat 773
    F-350, 1999, 4x4, 16' 10K# trailer
    Outdoor Wood Burner - 10 cords/year
    Jan 2011
    Tx
    I have done equip exhaust with a 3/32 6011. It took a few tries to vet where I wasn't burning through the pipe but it is doable. Keep in mind I had the exhaust off of the equip so I could move it to a good position for welding as needed.
    Miller Bobcat
    Harris cutting outfit
    Miller spectrum 625 plasma
    Variety of shopmade tools
    Guerneville Ca
    Quote Originally Posted by qaiphyx View Post
    Flux welding?? Do you mean FCAW wire feed?
    Or do you mean SMAW, (stick welding)?
    Stick welding a muffler TUBE even with 1/16 electrode would be almost impossible
    even if you were highly skilled.
    And don't forget about the sparks all around the gas tank area.
    Here is what you should do.
    Cut off the old tube back to good metal.
    clean the tube. Insert the new tube and muffler and put on the muffler u bolts and tighten with a wrench. -Done no welding.
    Just like a brand new car.
    AWS certified welder
    Jan 2011
    Pensacola, FL
    Quote Originally Posted by Donald Branscom View Post
    Guess I'm highly skilled. I welded my 5" stacks up with an AC225 and 1/16" 6013's. Not ideal but it was all I had at the time
    Jan 2011
    I am far from being a skilled welder.I have welded new exhaust tubing with 308 stainless.I had a new exhaust pipe wrong year.It was 4 inches too long.The end of the pipe was offset so I could not just cut off a piece.I cut out the 4 in section and butt welded the pipe. Used an old welder and did the job on the bench.When the car was rusted away from salt the weld was still sound.I use stainless a lot.3 /32 rod is what I use.Cant weld at all with 1/16
    Dec 2009
    Stevens Point, WI
    I welded up exhausts for years with my miller thunderbolt before I got my TIG. Anyone wanna buy a miller stick welder?
    Jan 2011
    Central Texas
    Quote Originally Posted by nadogail View Post
    ....I have not been in a working muffler shop for a lot of years; back in the day the shops all welded every thing with an oxygen / acetylene torch. Nobody working in a muffler shop was skilled enough to sucessfully arc weld mufflers and pipes.
    Thank you. That is my experience too...but maybe I am too shade tree to understand this.. or making bad assumptions..
    1. Usually the exhaust is welded not only in place...but with the vehicle supported by the wheels.... so as to be able to judge interferences when on the road better.
    Perhaps some of you who are not taking it off and welding it on a table have the advantage of adjustable lifts AND auto darkening helmets... or can weld without having to see where your bead is being applied ?
    My experience is limited to welding with the vehicle on the ground ... or at best all four wheels on ramps... me prone on the ground trying to bend up enough to see the top of the pipe and what was behind it I could catch on fire... with a flip back helmet there is not the room in most situations to be that high into the machinery where the helmet could be flipped down... whereas oxy-acet goggles are just fine.
    Then after you weld it... if you want to check for leaks... visually .... it is pretty easy to view an oxy-acet bead with a mirror with no prep... but getting slag off the top side of that pipe in such a tight space is a real problem for me..... and I would have burned through because I would be distracted from the sparks hitting the ground or concrete and rolling under me.... very distracting to me... ouch.... and even potentially setting my shirt on fire... but I do wear snap shirts instead of buttons so I can exit them fast...
    But really,... what Donald B said :
    "Here is what you should do.
    Just like a brand new car. "
    Becomes smarter and smarter looking the older one gets... if something has to come back apart to reach something else... .or the next time it needs fixing..... you can usually do it with already bent and spread items from the local O'Reilly's...and can still weld it up if you really want to... but exhaust pipe clamps have worked perfectly for millions of cars.
    WW2 era Miller TIG.
    Feb 2010
    Northern MN
    Still is leaded. Lots of av fuel is 101LL which is 101 octane low lead. still leaded just not as much
    Jan 2011
    Pensacola, FL
    Quote Originally Posted by ironmangq View Post
    it's 100LL
