tig cast steel to mild steel
Results 1 to 11 of 11
    Apr 2011
    houston tx
    About to weld some axle tubes to a pumpkin of my rearend. Also a torque arm mount. What I need to know is for tig, what wire do I use and preheat postheat process. Thanks
    Nov 2007
    Re: tig cast steel to mild steel
    ni44 nickel filler rod
    Jan 2006
    In A Nice Comfy Chair
    It's STEEL ed..
    No pre heat..
    No post heat..
    70S-2 Filler and have at it.
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Apr 2011
    houston tx
    70s2 even on cast steel. I had talked to a metallurgist a couple days ago he recommended 80s-Ni1. But we don't have that at work. 70s-2 is in abundance. He also did not recommended pre/post heat. So I should be good with straight up 70s-2
    Apr 2007
    Prunedale, Ca
    Is it cast STEEL or cast IRON? big difference. If you hit it with a grinder, cast iron doesnt throw much of a spark, and the cast steel will look like your regular old mild steel... Not very "hi tech" but it has worked for me thus far
    HTP Invertig 201
    Lincoln Idealarc SP250
    Miller 180 AC Stick
    By farmall:
    They should have held the seagull closer to the work, squeezing evenly for best deposition.
    Apr 2011
    houston tx
    Steel
    Apr 2011
    houston tx
    At least everywhere I've read on the 8.8 Ford rear it is cast steel. Ill grinder check it first but I'm about 95% positive its cast steel
    Apr 2007
    Prunedale, Ca
    On 8.8s I have always just stitched the tubes to the housings, no issues. I think those centers are cast steel
    HTP Invertig 201
    Miller 180 AC Stick
    By farmall:
    Zap said it all this is how mine is done never had any issues. It seems most mig weld them as I have done in the past too.
    Apr 2010
    Galesburg, il USA
    Quote Originally Posted by drago1217 View Post
    +1 on the E70-s2, The E80-Ni1&2 are really 90ksi welds and usually used where there is trouble with 100ksi steel and cold temps or severe impact is causing problems.
    That said, if you ever get a chance to use it, E70 fillers will seem like sewage, it flows amazing, maybe the best look of all low alloy steel fillers.
    Matt
    Apr 2011
    houston tx
    Thanks everyone you have put my mind at ease. Ill be starting this project very soon. Hybrid rear end. 8.8 rear with my Trans am tubes for my 02 ws6
