Oxweld or Purox to Victor tip sizes
Results 1 to 6 of 6
    Apr 2009
    Boise, ID
    I've got an old Oxy-Acetylene Handbook here and I've been reading through it trying to familiarize myself with some techniques before burning up some steel. They reference Oxweld and Purox blowpipes and tips only. I might be wrong, but some of the tip number sizes they mention for welding thin steel seem significantly larger than a Victor tip number.
    Are Oxweld, Purox and Victor tip size numbers the same or different? If different, is there a conversion table readily available to convert to the Victor sizes?
    Mar 2008
    Greater Seattle, WA
    Re: Oxweld or Purox to Victor tip sizes
    I have a Purox oxy-acetylene cutting/welding setup and I can vouch that yeah, the tip sizes are waaay different than the tip sizes of other, more common brands. I don't know where a conversion chart from Purox tip sizes to other could be had, at least off-hand. Howevrer I do have a chart I use showing what size purox tip to use (and also what gas pressures to set) for various thicknesses of metal being welded or cut.
    Edit: 5 minutes on google and I found a cutting torch tips size chart for various brands of cutting tips, here:
    http://www.airgas.com/content/detail...=7000000000128
    Edit 2: and here is a welding tips chart for various brands:
    http://bikesmithdesign.com/Welding/tips.html
    Aug 2009
    Chart saved for posterity. Zoom in to read or save to disk then zoom if necessary.
    Apr 2009
    Boise, ID
    Quote Originally Posted by jakeru View Post
    Good find! I searched, but to no avail. There's definitely a big difference there. The book I have is a Linde book, so I suppose that's why they specify their tips. I suppose the oxygen and fuel settings in the book could differ from Victor as well then, huh?
    Seattle
    Quote Originally Posted by mechelement View Post
    If you need Victor data, why not go get that directly? Here's a sample best viewed with fixed-width font:
    VICTOR HEATING TIPS
    Style 11
    Fuel Oxygen Fuel CFH Oxygen CFH
    No. 8: 10-15 20-30 30-80 35-90
    MFA (acetylene only)
    No. 2 4-8 4-8 3-9 3-10 (100/300 series handles)
    No. 4 6-10 8-12 6-20 7-22 (100/300 series handles)
    No. 6 8-12 10-15 14-40 15-44 (100/300 series handles)
    No. 8 10-15 20-30 30-80 33-88 (100/300 series handles)
    No. 10 12-15 30-40 40-100 44-110 (100/300 series handles)
    No. 12 12-15 50-60 60-150 66-165 (310 handle)
    No. 15 12-15 50-60 90-220 99-244 (310 handle)
    MFN (use with 310 handle, all fuel gases except acetylene)
    No. 6 2-10 8-20 6-20 20-80 (100/300 series handle)
    No. 8 10-15 10-20 10-35 40-140 (100/300 series handle)
    No. 10 12-20 10-30 20-80 80-320 (100/300 series handle)
    No. 12 15-25 30-125 30-160 120-640 (310 handle)
    No. 15 15-25 30-125 50-200 200-800 (310 handle)
    NO. 20 15-25 40-135 75-250 300-1000 (310 handle)
    VICTOR WELDING TIPS (data covers W, W-1 and W-J series tips) (types 1,4,13,17)
    Metal Welding Drill Pressures (psig) Consumption (scfh)
    Thickness Tip Size
    (in.) Size Oxygen Acetylene Acetylene
    1/32 000 75(.022) 3/5 3/5 1/2
    3/64 00 70(.028) 3/5 3/5 1½/3
    5/64 0 65(.035) 3/5 3/5 2/4
    3/32 1 60(.040) 3/5 3/5 3/6
    1/8 2 56(.046) 3/5 3/5 5/10
    3/16 3 53(.060) 4/7 3/6 8/18
    1/4 4 49(.073) 5/10 4/7 10/25
    1/2 5 43(.089) 6/12 5/8 15/35
    3/4 6 36(.106) 7/14 6/9 25/45
    1¼ 7 30(.128) 8/16 8/10 30/60
    2 8 29(.136) 10/19 9/12 35/75
    3 10 27(.144) 12/24 12/15 50/100
    To approximate gross BTU output, multiply flow rate by factor below
    Acetylene 1470
    Propane 2498
    Methane 1000
    Propylene 2371
    Butane 3374
    Hellinois
    Tagged
    "Stick-man"
