Ultra flex orange whip lead
Results 1 to 19 of 19
    Hellinois
    I was wondering what size whip lead you guys use on your stingers? I was looking at getting some of that ultra flex orange whip lead. What amperage is 15' of # 2 and # 1 good for?
    "Stick-man"
    Apr 2011
    VA
    Re: Ultra flex orange whip lead
    #2 = 200, #1 = 250. I use #4 on my small stinger that I run 3/32 7018 with and occasional 1/8. I found this chart... http://gencable.com/index.shtml?cables/weld.htm ...other brands may vary...
    Sep 2010
    NY by way of TX, CA, MI, CT,...
    People have been recommending this place for lead. Supposed to be high quality and good prices....
    http://www.trystar.com/
    Haven't tried them myself, yet.
    I think they also have an ebay store where they sell lead at a discount, can't recall the seller's name thou. I'll see if I can't find it.
    mens agitat molem
    Sep 2010
    Ah-ha!
    Found it...
    http://shop.ebay.com/merchant/coppercableman
    They even print your name and number on the lead for free and ship for free.
    Nice.
    mens agitat molem
    Apr 2004
    Maryland
    I run a 10' whip of ultra flex 1/0 with a bernard short stub holder.
    Lincoln
    300 Vantage 2008
    300 Commander 1999
    SA250 1999
    SA200 1968
    Miller
    Syncrowave 200
    XMT350MPA/S-52E/xr-15
    Xtreme 12vs
    Millermatic 251 w/30A
    Millermatic 251
    Dialarc 250
    Hypertherm 1250
    GEKA & Bantom Ironwokers
    Hellinois
    Quote Originally Posted by welds4d View Post
    But those ratings are for 50'. I am only going to use a 10' - 15' whip attached to 1/0 main leads.
    "Stick-man"
    Hellinois
    Quote Originally Posted by ncfh View Post
    Last time I checked, they were a little high on price. I like the name option, but I would rather save the $.
    "Stick-man"
    May 2008
    Orange, TX
    At 250A, 15' of #2 will yield a 1.4V drop and 15' of #1 1.1V. Both would be considered very acceptable.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    Hellinois
    Quote Originally Posted by Xtreme Fabrication View Post
    I think I have #1 regular lead on my Tweco 316 & 732 and 1/0 regular on my short stub.
    I was looking to lighten the Twecos to maybe #2 or #1 ultraflex.
    "Stick-man"
    Jan 2008
    i have that orange whip. i think for the price i would have been happier with ten foot of regular #2....
    Hellinois
    Thanks Duane. But, can you explain how you determine if it is acceptable? Is it the voltage drop? How do you calculate that including the length consideration?
    I'm pretty lost when it comes to electrical. I have performed pretty much any trade, except that. It REALLY lets you know when you've messed up.
    "Stick-man"
    Hellinois
    Quote Originally Posted by weldbead View Post
    So the comfort benefits do not out weigh the price? I have never seen the ultraflex in my hands. I've just read and heard it's nice.
    "Stick-man"
    May 2008
    Orange, TX
    This is one of the calculators (at the bottom of the chart) I use for voltage drop checks. http://www.gadgetjq.com/wiring_size_guide.htm
    The actual voltage value you select is not important as the voltage drop is determined by amperes and wire/cable size and is the same regardless although it does affect the calculated % of drop so you may have to calculate that figure yourself once you know the total voltage loss and based on the rated/known weld voltage (not OCV). I like to stay under 3% total loss.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save 2nd Base!
    Sep 2010
    I don't like this type of cable for either my leads or for a whip. I know, I might be the only welder in the world that is saying that, but honestly I despise it.
    Its heavy for its cable size, and weight does mean something to me.
    The twist is different and so is the individual wire size. That also has proved out to be a factor too.
    I wouldn't buy it, I don't like using it, nor would I recommend it. Thats how strongly I feel about this orange stuff.
    I'd rather use plain old black cable. I know what it is.
    Yea it's not all that flexible, but its twisted tightly and it is made of very small wires. Get some cross feeding going on and you'll understand why that might be important...
    If it gets stolen I loose money, but I don't loose double!!!!
    Count me out of the orange cable (whip) movement. I'll stay with the black stuff.
    And for the question about what size whip cable do you need..... "if you find yourself thinking about your cable while you're welding then its too big". It should be - seamless man. You should not be thinking about how you're going to do this or that because of that big heavy whip cable. If you are then you need a smaller cable. "it'll burn up!!!". Yea, and when it does then replace it. See, thats easy to.
    Good luck
    Later
    Jun 2009
    TEXAS
    I'll second what slowhand stated. #1 black cable does everything I need. I used to air arc all day with 1/0 cable and 3/8" air arc rods. Slowed down long enough for the compressor to catch up. So that's running 400 ? 450 amps at near 100% duty cycle ? I don't air arc because nobody calls me for that type of work anymore. Save some money and your back and buy the black #1 or #2. Not saying it isn't a good idea to have the heavier cable ready for larger jobs - -if you get into jobs that require it.
    Hellinois
    Thanks Duane, I'll have to play with that. And then I will PM you with my questions!
    "Stick-man"
    Hellinois
    Quote Originally Posted by slowhand View Post
    Good luck
    Later
    This is exactly why I was going to go with smaller whips. When I was making those chicken ladders I posted about, MAN! three hundred chicken ladders = 1200 one inch welds and 20 lbs. of 1/8" 7018.
    So I bought a 200A stinger and a 10' 4ga lead just for this work to lighten the load on my shoulder. Then I was thinking of litening up my other stingers. But if the orange stuff weighs more, forget it. I will just go with a 2ga and a 1ga black.
    "Stick-man"
    Aug 2009
    Try old gas-cooled TIG power cables if you can get them. We just dyked off copper TIP of the cable end, slid off the threaded fittings, and squashed the ends in our QDs/electrode holders.
    Flexy, work fine, and according to the pipe weldor instructor this is very common on jobsites and a great use for leaky TIG cables. I made a bunch of them for the students and they were quite popular.
    Hellinois
    Sorry to quote myself, here's a pic. Can't wait to feel the difference.
    "Stick-man"
