Ceramic cup when TIG welding...
Results 1 to 5 of 5
    Jul 2006
    Langhorne, PA
    How does changing the diameter of the ceramic cup effect the work?
    Im very new here.
    Also, is dragging the ceramic cup or using it as a lean point for the torch acceptable in "free hand"?
    Jan 2006
    In A Nice Comfy Chair
    Re: Ceramic cup when TIG welding...
    Quote Originally Posted by Jon K
    Im very new here.
    changing sizes only makes the shield zone bigger or smaller..
    i even have one that i ground down halfway..so i can get into small places...
    and you never drag it or use it for "leaning"..learn to keep it up about 1/8" with your hand only.. get comfy in a nice chair and use your elbow to do the leaning with....
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    May 2006
    Augusta, GA
    Your can download about a complete basic handbook about TIG welding at this website http://www.millerwelds.com/education/TIGhandbook/ and I believe choosing the correct electrodes, cups, and filler rods are discussed in the book. Each chapter is a PDF file that can be opened and printed using Adobe Acrobat Reader. There is also a handbook for MIG welding. Be advised that the material may be technically slanted toward Miller welders, but the basic information agrees with other sources I have read.
    May 2006
    Also remeber that the larger the cup, the more argon flow you will need.
    Jun 2005
    New Zealand/Australia
    Sounds to me like you need to learn to 'cup walk', that should sort you out
    Stephen
    I'd rather be hunting........
    USE ENOUGH HEAT.......
    Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
