Can a PowCon 300sm Tig weld if it has a plugged in pedal?
Results 1 to 10 of 10
    I'm looking at a PowCon 300sm to buy and noticed it has a PowCon pedal plugged into a factory port. I know the "sm" stands for Stick and Mig but can you Tig weld SS and mild steel with this machine? I know it can't Tig aluminum without a HF box.
    thanks in advance for any replies!
    Mike
    Jan 2015
    Alaska
    Re: Can a PowCon 300sm Tig weld if it has a plugged in pedal?
    There's no gas control solenoid on those, so you'd have to run a torch valve, also no cap discharge start so you'd have to scratch start. But the pedal should control your current. Have to check the pinout and machine pin out, but I'm about 95% sure
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Powcon 300st (my favorite)
    Miller Goldstar 600ss
    Lincoln Idealarc 400/400
    Miller 12vs
    2 LN25's
    Miller Deltaweld 302
    Miller Bobcat 250 G EFI
    Miller Bobcat 225d Plus (Dropped a valve, up soon)
    Everlast 255ext (ordering soon!)
    Quote Originally Posted by stevenopolis View Post
    Thanks! That tells me all I need to know. Not real big on scratch start, think I'll pass on this one.
    Jan 2015
    Alaska
    They are great power sources that take a beating. I shoot for them on ebay for 300-350 bucks. Arcon offers tons of support for them as well. I've worked with their technicians on Sundays before. They are very dedicated people.
    Miller 12vs
    2 LN25's
    They have rave reviews but I've never heard of them before. Been working around metal fab for 30 years and don't remember seeing any lol. We had a couple xmt's in a tool shop I managed and they were really handy machines. They'd Tig like a dream.
    Do you know if you can plug and play a spool gun on the 300sm?
    thanks,
    Mike
    thanks,
    Mike
    Jan 2015
    Alaska
    Not sure about that. I don't know much about spool guns. If they run off of the welding current and just have a remote switch, as long as you have the right 14 pin setup for remote contact, I don't see why they wouldn't push al wire.
    Miller 12vs
    2 LN25's
    May 2010
    Sparks, NV
    You generally can't TIG aluminum with a DC welder. You need AC and HF continuous. (For the average welder weldor) Before some wise guy gets on here. Yes you can do DC with helium but it's a specialized process and primarily for thick aluminum.
    AHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; ESAB 875 plasma;Evo 355. OA
    Feb 2009
    Central Illinois
    Scratch start works fine on SS and carbon steel. Never had a lift start until I bought my XMT. As far as using a pedal I have never used one. I don't see a need for one welding DC tig.
    There are threads in the powcon section about adapter cables for feeders.
    Dan D.
    Manipulator Of Metal
    May 2010
    Sparks, NV
    Both my ESAB suitcase and ready welder ran fantastic off my Powcon machines when I had them
