Help with how to weld 1/2" nut on end of 1.25" sq tubing
Results 1 to 13 of 13
    Mar 2007
    I'm working on a small project currently and I'm trying to figure out how best to do the following:
    I'm using 1.25" square tubing and would like a 1/2" threaded hole on the end. I thought there might be inserts similar to what they have for round tubing but can't find any.
    Is there a better way then to - cut some plate to size, drill a hold larger than 1/2", weld nut onto plate, then weld onto tubing?
    May 2008
    Fraser Valley, B.C. Canada
    Re: Help with how to weld 1/2" nut on end of 1.25" sq tubing
    Quote Originally Posted by TeCKis300 View Post
    That is exactly how I would do it.
    Jul 2011
    Utah
    I just did this when I put casters on my welding table.
    Cut a square out of 1/8" that's less than 1.5" (but not small enough to fall in the tubing), this way you have a corner to fill in with weld, it makes for a nice finish and leaves a gap for full pen. Fine the center by scribing with calipers and drill a 1/2" hole and (tig) weld the nut on. Cool the part and run a tap through the nut into the plate (the plate will be in the way slightly, I dont recommend skipping this step). Then just weld it on to the tubing.
    Apr 2010
    You can also screw in a bolt with some anti seize on it to keep from messing up the threads and help keep it straight
    Don't over heat the nut as it will soften the threads
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Apr 2011
    minnesota
    Or use thicker plate and drill and tap a whole.
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
    Sep 2009
    Sedona, Arizona
    Syncrowave 200 Tig Runner • Lincoln Power Mig 216
    Hypertherm PM30 • Scotchman CPO 350LT Cold Saw
    Cincinnati 1810G shear • Bluco 5x10 Fixture Table
    5000# Toyota Pneumatic • Dodge 3500 DRW
    Mar 2006
    Yuma, Arizona
    JimmyPop, that is wicked badazz!
    Lincoln Precision TIG 275,Undercart cooler,Foot/Finger Amptrollers
    Lincoln Hobby-Weld 110v
    Lincoln SP-200 MIG and Hi-Freq Tig
    May 2008
    Orange, TX
    If you used a square nut, you could notch the corners of the end of the tubing such that each edge is the same dimension as the side of nut at the end, bend the sides in to form a smaller ID square the same size as the square nut OD and weld it up. Run a tap in when done if you don't use a bolt and anti-seize.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    '68 Red Face Code #6633 Under Construction
    Star Jet 21-110
    Mar 2006
    Yuma, Arizona
    Duane,
    Why would you want to go that route? Those weldnuts are way cooler.
    Apr 2010
    Quote Originally Posted by Joker11 View Post
    Duane,
    But the price is not
    I can buy a lot of nuts for 17.99 plus
    Optrel Welding Hat
    Arcair K4000
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Jul 2011
    Utah
    Too bad none of those products apply or help at all...
    May 2009
    San Luis Obispo, CA
    Ian Tanner
    Kawasaki KX450f and many other fine tools
    Nov 2010
    NH
