helmet lens fogs up
Results 1 to 10 of 10
    Apr 2007
    helmet lens fogs up
    I have a Lincoln Vista helmet and I'm having problems with the lens fogging up while welding. The fogging is occuring between lens layers and takes a fair amount of time to clear once they have fogged up. Anyone have any recommendations on how to stop this? Any advice would be appreciated.
    Jul 2009
    SW Washington State
    Re: helmet lens fogs up
    Hello DeerMan, I have a couple of suggestions. First, take some black electricians tape and wrap it around the edges of your lens while they are stacked, this will seal the inner shaded lens from picking up moisture. Second, go to your local sporting goods store and pick up some sort of no-fog spray or other type of anti-fog and use it as suggested by the manufacturer. Between these two suggestions and others that will likely be given to you, you should be able to get a handle on the fogging issue. You're certainly not alone with having this problem, lot's of other folks have faced and conquered it right along with you. Best of luck and regards, Allan
    aevald
    Utah
    IIRC a little bar soap (hand soap) rubbed in the surface, then rubbed clean works to keep things from fogging.
    Soda springs,Id
    Also breath thru your nose all the time hood is down. This creates a downdraft keeping the warm moist air away from the lenses.
    Mike
    Ol' Stonebreaker
    Miller 175 mig
    Hobart G-213
    Victor O/A setup
    Makita chop saw
    Sep 2011
    Da UP
    rainaway might help the situation if you take the lenses apart to apply it.
    another antifog agent is spit, and wipe, but its fairly short term. good for an inner lesne fog though.
    Jan 2008
    Billings, MT
    pancake hood
    Lincoln Pro Core 125
    Lincolin sp 100
    Miller Big 40
    Lincoln Idealarc SP250
    miller matic 212
    http://www.facebook.com/hdwelding?sk=wall
    www.hdweldingbeds.com
    Apr 2010
    Quit breathing in there.
    Used to know a guy who smoked all the time under his hood
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Aug 2009
    Scuba divers wipe spit in their mask as anti-fog. It works pretty well on welding lenses too.
    Not recommended if you are chewing tobacco...
    Northern Cal., Shasta County
    Take a short piece of masking tape, black tape or freezer tape and run it across the bottom of the lense or lense cover just barely catching the bottom edge and well down on to the mask area below the lense. It doesn't stop the surface fog but it stops the fog from getting between layers. Don't use some gooey tape like duct tape cuzz it will leave glue when you peel it off. Warm the hood up a bit before putting it on for welding. The disparity in temps increases the fogging.
    I try to use some cheaper masking tape where the glue just sort of dries up with time.
    Sep 2011
    Between welds, I keep the inside of my hood under the flexible light on the band saw. That and Rainx anti-fog works for me.
