PQR for AWS D1.1
Results 1 to 9 of 9
    PQR for AWS D1.1
    Does AWS D1.1 allow 1 PQR (full penetration) to qulalify multiple WPSs for partial peneration. Asuming same process. For example:
    A514 to 44W
    MCAW
    1 X Fillet, 1 x Sg. Bevel PJP, 1 x Double Bevel PJP & 1 x Flare Bevel.
    All qualified by 1 full penitration PQR.
    SoCal-LA
    Re: PQR for AWS D1.1
    That makes sense to me, but I don't know if those are dissimalar metals that need a compatible filler.
    This is a great question for the AWS discussion forum.
    Miller Dynasty700DX, Dynasty350DX 2ea., Dynasty200DX, ThermalArc 400 GTSW, LincolnSW200 2ea., MillerMatic350P, MillerMatic200 with spoolgun, MKCobraMig260, Lincoln SP-170T,PlasmaCam/Hypertherm 1250
    All are Flat/Hor using E76C-K4-H4 (E110C-K4-H4)
    Anchorage Alaska
    To my understanding each joint type would need a WPS when any of the essential variables are changed.
    SoCal-LA
    Quote Originally Posted by Fat Bastard View Post
    That is my understanding, especially concerning weldments of dissimilar metals.
    I think I found it:
    AWS D1.1 - 2006. Table 4.5 - PQR Essential Changes Requiring WPS Re-Qualification. General - Para 31. Page 139. Not sure if this cover it, but it sound like for groove type, a CJP will cover it.
    Anyone go a copy of the 2006?
    May 2011
    newport news virginia
    all of them need a seprate wps....not sure about the fillet weld..
    SoCal-LA
    Quote Originally Posted by sixxgeeee View Post
    But you can generate many WPS from a qualified PQR.
    AWSB2.1, section 2.1.5 states; "A WPS may require the support of more than one PQR, while one PQR may support a number of WPS,s. PQR's qualified using different processes may be combined to support a WPS."
    If you write your WPS loose enough, you can tackle many applications IMO. Best to review the spec.
    Jul 2009
    Dayton, OH
    Quote Originally Posted by johna@ddi View Post
    A514 to 44W
    MCAW
    I think I found it:
    Looks like you are on the right track. I am using AWS D1.1 2008.
    Table 4.1 Qualifcation Test> Weld Type> CJP Groove> 2G
    Qualified for F, H in the following Groove CJP, Groove PJP, and Fillet
    Then Table 4.5.31 Any CJP groove weld qualifies for any groove detail conforming with the requirements of 3.12 or 3.13. (These are all of the prequalified joint types listed in Clause 3)
    So you should be able to have one PQR from a CJP Groove 2G welded plate in the appropriate thickness to meet your requirements. This will satisfy the requirements for multiple WPS's that will cover your joint design changes (make sure your PJP joint designs are covered in Table 3.12 or Table 3.13).
