Wood Burning Stove Repair
Results 1 to 10 of 10
    Jul 2011
    Thera a nice stove on CL for $100 near me. It's cast iron, and has a longitudinal crack across the back. I was thinking of these ways of repairing:
    Lighting and keeping a fire going in it so it preheats and cools slowly and then,
    Brazing w brass (don't know if that will hold up to the continuous heat)
    Welding with Nickel rod, but I'm unsure if this is a tig filler rod or a stick rod.
    Thanks
    TA Arcmaster 300
    CM3
    XMT 304
    S22P12 suitcase feeder
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
    Stihl 020AVP, 039, 066 Magnum
    Jan 2011
    Pensacola, FL
    Re: Wood Burning Stove Repair
    I'd use Ni99 rods. I get them as stick rods and knock the flux off for using them with TIG. A small fire may do a good job for preheat along with a good job of cleaning out the crack. offer the guy $50 and see if he'll bite
    Nov 2011
    What Timberwolf said... $50 because a welding repair may or may not work, and you'll spend at least 20 bucks on Ni99 stick electrodes (last time I checked, they ran about $60 per pound). It would kind of suck to part ways with a Benjamin only to end up with a heavy object for the scrapyard.
    Try to groove out that crack as much as possible, and I vote for the Ni99 rod.
    Apr 2011
    Grind a slight groove in the crack, drill a small hole at each end of the crack to keep it from spreading due to expansion & contraction, knock the flux off a stick of Ni rod & tig it up.
    Jul 2011
    Bossier Parish La.
    Quote Originally Posted by BCTimberwolf View Post
    Would this work using the Ni99 stick rods as stick rods with the flux on as intended? I ask because I have a cast iron heater with a crack, but don't have TIG capability. But I do have a Bobcat to stick rod weld it, or would a O/A torch be the way to go with this rod and no flux? The crack is on the side and I can get the side glowing red hot with a good enough fire, then let it slowly burn out for cool down.
    Nov 2011
    Quote Originally Posted by Old Skool View Post
    I thought nickel tig rod was less than Ni99 SMAW rods... could be wrong.
    Oct 2007
    Yuba City, CA
    CI stoves (and exhaust manifolds) showing cracking, may also exhibit an expanded, grainy looking surface from long term heat, oxidation, etc.
    This skin may be 1/4 of the parent thickness.
    I called this 'cooked'.
    With cooked CI.....even grinding the skin away, doing a bevel groove
    weld/braze with good prep, preheat, etc.......just may not work in the
    short or long term. When cast gets really cooked--it isn't CI anymore
    and is not weldable. The remaining 'good looking' CI exposed by
    grinding, just may not be 'good-enough' for a lasting repair.
    Additionally--you're describing a crack spanning apparently a large
    section. Large sections are 'restrained' at the edges by the cast design
    and/or simply their proportionately large size.....
    ....So What?......the resulting heating of the welded crack, followed
    by cooling, is setting the stage for more cracking--often despite
    one's best efforts.
    All in all--unless a detailed inspection as to 'why?' the crack,
    a big crack in a wood stove is pass.
    Blackbird
    Western PA
    Scrap is around $10/hundred around here, last I checked. I wouldn't give more than scrap value.
    Feb 2007
    West By Golly Shelby NY
    Tough one to fix. Hot and cold will eventually crack it again some place else.
    David
    Real world weldin.
    Jun 2010
    I would recommend Dave Powelson advice.
