Is it possible to increase the AC frequency on a 2001 lincoln 275 SWT?
The manual lists the factory main rectifier gap at 0.15 (.4mm) set for most applications and notes that the gap can be reduced if less high frequency is desired but does not mention anything about increasing the frequency. Will increasing the gap increase the frequency? Will it cause damage to the machine?
