TIG filler rod holders???
Results 1 to 25 of 36
    Oct 2011
    I just bought a couple 15" plastic tubes at my local welding store. I had to cut them up and tape them together to make one that would fit an 18" filler rod.
    Is there a place online that sells these tubes in an 18-20" size?
    OR, what does everyone else do?
    Feb 2007
    West By Golly Shelby NY
    Re: TIG filler rod holders???
    Plastic Rod guards. I have many.
    I think most just use the box it came in.
    David
    Real world weldin.
    Oct 2011
    Quote Originally Posted by David R View Post
    David
    That's what I bought but I can only seem to find them in 15" or 36"?? I cut my rods in half so I need 18" or so... Plus, the wall they will be on is only 24"
    Dec 2011
    Colma, CA
    PVC pipe cut to fit put on end cap's your good!
    AEAD 200LE, Lincoln precision tig 185, Millermatic 251, Spectrum 625 extreme, Victor torch , Smithy 1220LTD. and Do all C-4 band saw , Always adding.
    Oct 2011
    Quote Originally Posted by houseoffire View Post
    Bada Bing, Bada Boom!! That's it!!! Thank you!
    Mar 2007
    SW PA
    Hey CGC,
    Yup.... PVC. That's what many of the fellows do....easy to store, small footprint, & you can store them vertically or horizontally.
    Denny
    Complete Welding/Machine/Fab. Shop
    Mobile Unit
    Finally retired
    *Moderator*
    "A man's word is his honor...without honor there is nothing."
    "Words are like bullets.... Once they leave your muzzle, you cannot get them back."
    Feb 2007
    These come in 36"
    http://www.rodguard.net/
    David
    Real world weldin.
    Oct 2011
    These come in 36"
    David
    Those are what I bought locally. The only problem is the ones that say 18", are really 15 1/2" ... I bought two of them and made one 19" tube.
    The PVC is a perfect solution to what I am wanting to do!
    Maryland
    If you are going with 'stock' length, the rod gaurds can be found for about $10. I think they are actually water tight. They do have a rubber seal. And yes, two sizes, full TIG filler size and stick rod size.
    Making your own with PVC is a popular alternative. Just watch your costs. By the time you buy two caps, glue, butt joint etc. you will probably be close to that $10 number.
    I built a rack with 4 rows and 8 columns of holes to hold up to 32 of these filler tubes. 4 rows because one row is dedicated to .030 or .035, the next to 1/16, the next to 3/32 and the last to 1/8. 8 columns for the different materials - 3 different stainless, 2 different aluminum, 2 different steel, one bronze. Not all the slots/holes are filled - and I suspect some will never be emptied.... (its just a hobby for me).
    Con Fuse!
    Miller Dynasty 350
    Millermatic 350P
    -Spoolmatic 30A
    Miller Multimatic 200
    Hypertherm PowerMax 1000G3
    Miller Maxstar 200DX
    Jul 2009
    SW Washington State
    Noticed the mention of using PVC for rod holders. Have a number of them that I made quite some time ago. These are for stock length rods but could certainly be made to any length required. As to cost, if you are going to be making quite a few they can be very economical. Good luck and best regards, Allan
    aevald
    Feb 2007
    As was already mentioned, you cannot beat the Rod Guard brand tubes unless you just happen to have a whole bunch of PVC stuff just lying around.
    I have these attached to my TIG machine. Work very nice.
    Plus, if you are in a climate with high humidity or drastic temperature change, the RG tubes keep your rod sealed up from moisture. At least to an extent they do.
    Those are it. Just buy one now and then, next thing you know you will have a bunch. I have a lot on the shelf in the original box and some tubes labeled. I write on them with a sharpie. S2 and S6, stainless.......
    David
    Real world weldin.
    Jan 2006
    In A Nice Comfy Chair
    I like the cardboard boxes it comes in..
    Humidity and moisture has NO effect on steel tig wire.
    The LWS don't keep it in plastic tubes do they?
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Tustin, CA
    I just made some tubes out of 2" PVC. Just be sure to glue the bottom....otherwise it becomes a game of pick up sticks...
    Jan 2006
    The whole shop is non climate controlled..
    I have 1/8"!! filler that is open and never used..For obvious reasons....and is still like new.
    And it's 4 years old.
    I don't get the plastic bags around mine new and they are Harris!
    Just sayin.
    (Maybe if you used it fast enough you would not need the plastic)
    ...zap!
    Do not attempt.
    May 2011
    Upstate NY Catskill Mountains
    i have some 18" tubes dont know where I got them from, but I cut the filler in half and store it in the tubes
    Nov 2011
    Oklahoma
    I know this is not a worry for most on this forum but rust no matter how small will transfer hydrogen into the weld metal and base metal......from tig rods and mig wire. Not that much of a worry for regular welding but for high strength or vibration services need to keep that wire/rod very clean......just an FYI
    A young green pipe welder asked an old salt one day...How can I make the weld on the bottom of the pipe look like the top.......The old salt replied....Screw up the top......
    Jul 2011
    Queens, NY
    I use the rod guard tubes and keep different thickness filler in individual bags within them. II have a dusty shop so moisture aside I wouldn't want to leave them exposed.
    IW Local 580 NY, NY
    May 2008
    Orange, TX
    Why not? I'll throw mine up again.
    Name:  Filler Rod Storage 006.jpg
    Name:  Filler Rod Storage 007.jpg
    As I've stated before, I'd use some larger tubes as well if I did it again.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2011
    North,Ga
    I just use PVC tubes...
    Lincoln pro mig 180
    Lincoln Square Wave Tig 300/wp 20/home built water cooler
    Victor, Purox, Harris, O/A welding/cutting setups
    Vintage Craftsman drill press
    Vintage Craftsman/Atlas 12"x 36'' lathe
    7''x 12'' w/c band saw
    Everlast 140 st
    Sep 2006
    MS
    I made this on a slow day @ work.
    Sep 2006
    MS
    Sorry pic didn't work.
    Dec 2011
    Colma, CA
    I like that design, long caps and you can keep real short stuff in there. Nice!
    Nov 2011
    I think I spent 12 bucks on a 10foot section of PVC... not too terrible. Should be able to get 3 holders easily. Caps were prolly about 1.19 each. So still under the 30 mark :-)
    Now I just need to add into my collection of filler rod haha 4043 3/32 is all I have now
    Joe
    Miller 140 Autoset (2010)
    Miller Syncrowave 250 (1996)
    Feb 2009
    Chicago
    Does moisture,humidity have any affect on any tig rods? (aluminum or steel)
    Hypertherm Powermax45
    2015 AHP Tig
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    ViperMig 180
    Razorweld, SSC Foot Pedal & MK Products & Atlas Positioner Dealer
    Nov 2011
    Nova Scotia
    I use ABS or PVC with threaded caps on the top. You can make them any length or diameter you like. The threaded caps keep them moisture-free. Good for SMA rods as well...Don
