Miller Syncrowave 500
Results 1 to 20 of 20
    Feb 2007
    Miller Syncrowave 500 Tig/Arc welder. Machine was manufactured in 1980, it is capable of welding at 625 amp (40% duty cycle), has high frequency, and has a built in wasted water cooler. It weights approximately 1000lb, power supply is 240V single phase. It is in good running condition however I have not used for a few years, will make a great aluminum runner. Machine is under power and you are welcome to come and test it prior to purchasing, can load to buyers transport. Call/text (317)9120520. Welder is located in Indianapolis Indiana. Asking 1500$.
    Mar 2005
    Under a Rock
    Re: Miller Syncrowave 500
    Paging Michael Ray....
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Mar 2016
    North Georgia
    It's cool but my old air products never even leaves the low range setting
    Nov 2010
    SE Nebraska
    My 350 pulls over 120amps on 240v couldn't imagine what that ol girl pulls!!
    -Doogie
    Miller 350P
    Miller Trailblazer 325 EFI w/ Excel Power
    Lincoln LN25 suitcase welder
    XMT 304/22a feeder
    Miller Syncrowave 350LX
    Miller Econotig
    Hobart Handler 140
    (2) Uni-Hydro 42-14
    Hypertherm 65 plasma
    WEBB Gap bed lathe
    Mar 2016
    North Georgia
    First month I had my old shop set up the power board sent out an inspector... I had 2 aluminum rollback beds I took in to repair and I worked some late nights with my a/bp 330 doing 1/4 through 1/2 aluminum rail and deck repair.
    I knew the first bill was going to be high but I figured the jobs to offset that cost.
    The building was previously an old radiator repair shop that had 3 or 4 incandescent bulbs for lighting and just a small 110v air compressor.
    Power company thought that I had a short or bad meter but I hung 6 metal halide fixtures,installed a 220v compressor and worked that old miller hard that first month.
    Bill was little over $700 that first month.
    Average bill after that was $250-300 a month
    Feb 2007
    Bump. The machine is still for sale.
    Mar 2014
    NH
    Quote Originally Posted by Michael ray View Post
    Or might have thought you had started a "growing" business!
    Yep, that 500 probably dims the lights in the neighborhood when it is running at the top end.
    Thunderbolt AC/DC
    330AB/P + Bernard cooler
    Syncrowave 250
    Oxy/Ace torch
    Dayton 160 MIG
    6CF pot with 185 compressor
    Too much big equipment
    Even more small tools
    Mount Tabor VT
    I worked on a new house under construction in the winter of '93. The owner was a banker. They heated with oil fired torpedo heater. The owner lived near, and would fill the tank each night. He spilled a few drops on himself, and stunk all next day at the bank. He asked for electric unit heaters. I hooked three 5000 watt heaters up. They ran 24/7. In the day, the power company read meters every other month, and averaged for monthly billing. His first meter reading was a shocking figure. He called the power company, and convinced them the meter was defective. They replaced the meter, and settled for ten cents on the dollar.
    My conscience would never allow me to do that sort of thing. I guess that's how people get rich.
    Willie
    Feb 2007
    Bump, still for sale.
    Mount Tabor VT
    I'd pay $300.
    Willie
    Mar 2005
    Under a Rock
    I'd pay $300.
    Willie
    $325.00
    Hypertherm PM 45
    HTP 221
    Mount Tabor VT
    OK you win! $330. I got power enough for it. Likely, I can't afford the first month's electric bill, but I'll worry about that then. I once had a Dialarc 250 HF, 310 amps seemed unlimited in power! 625 amps AC should be plenty. I could do 1" thick aluminum. They don't make coolers for these torches, you have to live beside a river.
    Willie
    Jan 2008
    Lansing, MI
    Hell, you would need a separate transformer for your garage to run that sucker full out
    Dec 2011
    Ted Kennedys Socialist Utopia
    Why do I direly want this. I have a #12 torch NIB that would compliment it. Will take 5/16 tungsten.
    Miller Big 40G
    Miller HF-251 D High Freq
    Victor OA
    Lincoln 135 Mig
    MK 3A Cobramatic
    Bridgeport J Head
    Cronatron Oxylance
    Radnor ACAG Torch
    Weldcraft TIG Torches
    1 blown knee and two 5 Gallon pails away from being a hero.
    Mar 2014
    Beast of a machine for sure. But it looks like it's seen some hard use and maybe not been cared for all that well. I could see wanting to own it just for the "brag'n rights" it'd give you but in light of all the advancements that have been made in TIG welding machine technology in recent years I'm not sure $1500 makes very good economic sense.
    Jan 2008
    Lansing, MI
    Better off putting the money towards a dynasty. It was a good machine in its day and still is, but it's power hungry and big.
    Feb 2007
    I'm open to reasonable offers. However "$330.00" is too low.
    Dec 2016
    Ohio
    I would take the $330.00 since the machine is no longer supported by Miller. If a board goes out or you need a major part Miller is no longer stocking the. You would have to find the parts on the after market and that is not easy for this size tig machine. Miller stopped supporting equipment they no longer build after 7 years. This started in January 2016. There are a lot of old Miller welders that will soon be parts machines. Good luck!
    Feb 2007
    BUMP
    Completed a small TIG project (chair repair) this weekend. Welder works great even with high frequency.
    Lowering the price to $1300.
    Feb 2007
    BUMP, Still for sale.
