Cutting times, which saw is really most efficient? - Page 2
Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
    Mar 2013
    Savannah, Ga.
    Re: Cutting times, which saw is really most efficient?
    Quote Originally Posted by Teggy1 View Post
    Nope, the Hydmech "A" is automatic. Program length, Qty. required, up to 5 or so material lengths (on that particular saw) set head height, downfeed rate, push start and walk away. Automatic hydraulic head lift, unclamp, material advance, clamp, cut, repeat.
    Attachment 1580021
    Attachment 1580031
    Pics taken from web.
    Love those saws the shop I work at has two, there running all day every day.
    Sent from my XT1585 using Tapatalk
    Jan 2013
    ...Shoulder of Orion...
    @ Teggy1 - for small and mobile apps, we dig our HEM Femi ABS120 bandsaw. Looking into the future, we're in tradespace mode for a 1" blade, dual mitering band saw for larger capacity and heavy-duty work.
    Although we haven't exhausted the search, the HydMech DM-10 appears to meet our baseline requirements. Appears well built and supported by our allies in Canada.
    Do you have any experience in operating a DM-10? Within the saw's performance and price class, attempting to match a Made in USA equivalent saw. Searching Dake, DoAll, Wellsaw, etc.
    The DM-10's VFD driven 2Hp motor (165-325 SFM) would support cuts to NiCr:NiCu alloys (Inconels, Monels). Jam.
    Appeciate any insight you have on the DM-10.
    Feb 2014
    Iowa
    ManoKai, the only Hydmech experience I have is the S20A.
    Miller Dynasty 350
    Miller CP300
    Miller CP200
    Lincoln Idealarc 250/250
    Smith torch
    Lagun FTV-2
    Kent 13x40 TRL lathe
    Bunch of other metal cutting tools
    Jan 2013
    Understand. Thank you.
  5. #30
    Nov 2010
    VA
    I have more than a couple ways to cut steel, and each have their advantages. For sheer speed of cut, my old Milwaukee dry-cut beats them all. I'm not pulling my dry-cut and a piece of angle out for a test for a random internet question (sorry OP, no offense intended), but I'd be surprised if it'd take longer than 5 or 8 seconds to make the cut you're asking about, and the edge produced would be cool to the touch, shiny steel with hardly a tooth mark and nary a drop of coolant on it.
    There are a few disadvantages of the dry-cut saw, but those are well-documented elsewhere. Speed and cleanliness of cut are two of it's biggest advantages.
    Applied Fabrications, LLC
    Mobile Welding / Mechanical Repair in VA's Piedmont & Shenandoah Valley
  6. #31
    Nov 2012
    Land of the free, because of the brave!
    This is what I recently purchased. Cuts straight, and its made in the USA. Ellis 1600.
    Gar
    Lincoln Electric, Power MIG 256
    Hypertherm Powermax 45
    Miller Dynasty 280DX
    Smith O/A torch
    Genesis of a welding table
  7. #32
    Nov 2014
    Nice buy. How much horsepower?
  8. #33
    Hey, that sure looks familiar. Now you need to make some tables for both sides. I really like my 1600 saw. There are quite a few on WW that have them. You will love it !
  9. #34
    Laredo, Tx
    Cut this 2" pipe in 90 sec with fine blade with about 9 tpi 240 tooth and has stainless grind, then with the more course blade about 7 tpi 180 Tooth cut through in 50 sec. Both at a slow 78 fpm cutting speed. I'd though the blade that I put a stainless grind on cut worse after but if it last a lot longer that's ok. Attachment 1579761this is using 3/4 hp. Any 2" cutting times?
    That's slow as hell. My cheap evo multi-saw could make that cut in 15-20sec, easy.
    First person on WeldingWeb to have a scrolling signature!
    HTP Invertig221 D.V. Water-cooled
    Millermatic 211 Inverter MIG w/ Spoolmate 150
    Eastwood 40A Plasma cutter
  10. #35
    Nov 2014
    I was using the slow speed. I can spin the blade twice as fast. I bet ur evo don't cut straight like this one
  11. #36
    Laredo, Tx
    It sure does.
  12. #37
    Dec 2015
    Western New York State, USA
    old fashioned hss bandsaw is always going to be slower than the newer carbide tipped circular saws that have come out the past 10 years. they throw a few sparks but part is much cooler than using a abrasive saw
    circular blades last ok as long as part not vibrating same as part vibrating can destroy a hss bandsaw in a minute. biggest advantage with abrasive wheel saw is a little vibration does not usually bother it. if anything it cuts faster
  13. #38
    Nov 2014
    can u get ur evo to do this on 16 gauge stainless Oscar?Name:  image.jpg
  14. #39
    Laredo, Tx
    Sure can.
  15. #40
    Nov 2012
    Thanks! 1 HP, 110v model.
    Gar
    BD1,
    Ha! Very nice, and yes, i really like it.
    Gar
    Smith O/A torch
  16. #41
    Nov 2014
    Nice that's about what I got. I got 3/4 in low and 1.5 in high. Any cutting times?
  17. #42
    Feb 2015
    Started with a Mores dry cut Saw which I kept for about a day...then bought a new Ellis 1600 and it was ok, recently bought a cold Saw and the Ellis is now collecting dust....
    Cut time on 2" .135" wall 1030 tubing is as fast as you can pull 👍
  18. #43
    Nov 2014
    U must have like a 18" cold saw if it cuts steel like hot knife going through butter? I was cutting some 1/8" wall 1.250 aluminum yesterday and it felt like butter but on 2" steel not so much for me lol. I'm on a 10" scotchman blade. What blade pitch are u running for the 2" .135 tubing?how many cuts between resharpen? Thanks
  19. #44
    Feb 2015
    350mm x 2.5mm 220 tooth with 3hp vfd. Not sure on longevity yet, I have a stack of blades and re sharpening is cheap $10-$15
  20. #45
    New Haven, NY
    I actually made a Youtube video comparing my Evolution EVO380 to my friends Porter Cable abrasive saw. You can find it through the facebook link in my signature. I actually timed the cuts and everything on some of the common materials I cut. The Evolution saws cut fast and beautifully. Minimal cleanup involved after the cut.
    Miller Thunderbolt XL AC/DC
    Harbor Freight 90 Amp FluxCore
    Evolution EVO380 Chop Saw
    Evolution EVOMAG75 Mag Drill
    AHP Alpha TIG 200X
    https://www.facebook.com/weldnstuff/
