Extra Ground onDrill Handle
Results 1 to 5 of 5
    Hi, I bought a Big old heavy duty B&D hand drill on e bay It is a3/4" very slow rpm and very heavy
    Works Great! But it has a green wire coming out of the plug A ground I would think? which is wraped around a bare wire on the steel handle " A piece of pipe" Does this wire serve any purpose ?
    It is a 120v two prong plug Appreciate any thoughts, Thanks
    Mar 2016
    Northern Ca
    Re: Extra Ground onDrill Handle
    Does the wire connect to the plug in any way? You said it a two prong... If that is connected to mains earth at plug then it a hack way of grounding the exposed metal so if their electrical fault in drill then the handle won't be "hot". Although you said two prong so is it not connected or connected to neutral maybe?
    -Everlast PowerArc 280 STH
    -Hypertherm Powermax 30 XP
    Dec 2007
    Los Angeles
    Photo please
    Ed Conley
    MM211 (Sold)
    Passport Plus & Spool gun
    Miller 125c Plasma 120v
    SO 2020 bender
    Beer in the fridge
    Jan 2015
    Hamilton Ontario Canada
    If its like my old B&D dill it should have a 3 prong plug, and with a 3/12 wire running to it! It could have a safety aircraft wire to tie it to what ever you are drilling, usually for drilling at heights (can some times be chain).
    Welders: IdealArc AC/DC 250
    Lincoln AC 225 converted to AC/DC
    O/A torches
    Lots of Hammers Clamps and Grinders
    I have seen this on a different drill. The green wire is you safety ground. was supposed to have a fork terminal and you could put it under the receptacle plate screw. This only works if the plug box is grounded. Just replace the two wire plug with a good three wire.
    green to green, white to silver and black to brass.
