TIG Helmet-Mask Settings
Results 1 to 15 of 15
    Dec 2015
    Just learning to TIG.
    Have a nice Lincoln-Viking 3350 series auto-darkening helmet.
    What is the lightest SHADE setting I can use to TIG?
    (want to see as much as possible while learning on 1/8" aluminum)
    And can someone explain the SHADE 5-8 and SHADE 9-13 switches and corresponding SHADE wheel settings?
    Thanks!
    Feb 2009
    Chicago
    Re: TIG Helmet-Mask Settings
    Depends on your amperage and your eyes. Everyone likes it differently.
    I like mine at shade 9 up to 200 amps. But it will vary from person to person.
    Hypertherm Powermax45
    2015 AHP Tig
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    ViperMig 180
    Razorweld, SSC Foot Pedal & MK Products & Atlas Positioner Dealer
    Jan 2006
    In A Nice Comfy Chair
    Mine is either up or down.
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    SoCal-LA
    AC welding is a bright process. I prefer shade 10 myself. Too bright and I get eye fatigue. Too dark and I loose focus.
    If you have a Harbor Frieght autodark, remember to peel the protective film off.
    Miller Dynasty700DX, Dynasty350DX 2ea., Dynasty200DX, ThermalArc 400 GTSW, LincolnSW200 2ea., MillerMatic350P, MillerMatic200 with spoolgun, MKCobraMig260, Lincoln SP-170T,PlasmaCam/Hypertherm 1250
    Laredo, Tx
    What you don't want:
    What you do want (or at least as close as possible to it----you want to be be able to just barely distinguish the tip of the tungsten from the arc light).
    First person on WeldingWeb to have a scrolling signature!
    HTP Invertig221 D.V. Water-cooled
    Millermatic 211 Inverter MIG w/ Spoolmate 150
    Eastwood 40A Plasma cutter
    Nov 2014
    PDX PNW
    I'm on shade 10 most the time
    Joliet, IL
    You set it to what you want. Every shade is 100% UV protection. Brighter doesn't hurt your eyes, it can just increase fatigue. So just set your hood to what you're comfortable with.
    I like it as dark as I can get it and still see. Right now, I use a fixed shade #11 except for tacking, when I use an AD. As my eyes wear out, I expect to have to make it brighter, so the longer I can stick with #11, the better. If you're like me, you'll find that you can see the puddle A LOT better with a fixed shade than with an autodark.
    SoCal-LA
    Yup. I am the same way. Nothing beats my fixed Phillips Safety glass gold lens.
    Long Island
    Quote Originally Posted by JESFromRIC View Post
    Thanks!
    Not owning your helmet, my guess is 5-8 is for gas welding or plasma cutting, while 9-13 is what you would want for TIG. What does your instruction manual say?
    Anywhere from 9 and up should be safe for TIG welding (at all but extreme currents) with an auto-darkening helmet, but the shade you should use would be the one you are most comfortable with. Too light, and your eyes fatigue (as stated above) and you see spots that make the puddle hard to see clearly. Aluminum is quite reflective, so I'd probably be using shade 10 or 11 on my helmet in your situation (though not all helmet's shade numbers are perfectly calibrated to each other).
    Do you have blue eyes? Blue eyes can be more sensitive to bright light, and people with blue eyes often prefer one shade darker than people with brown (like myself).
    Dec 2015
    Thanks All!
    Sorry, didn't get post notification.
    10 it shall be!
    And, thanks for the great pictures too.
    Mar 2015
    usa
    alot of it also depends on the lens. at home i use jackson w60 trusight and can see just fine at 150a with shade 11. other lower qaulity lenses ive had to use lower shades and still cant see nearly as well .
    Dec 2016
    Cape Coral, FL
    I also have a Lincoln 3350 helmet, I use #9 most of the time, or #10 while doing aluminum due to the higher current and brighter arc. Nice helmet BTW! As stated above the lower shades are for grinding, etc.
    Aug 2016
    Got that Lincoln too, using for several months. Great helmet!
    Hard to understand how there are numerous shade settings, with this thingy.
    Like 2 circles of settings, one knob.
    Charl
    Dec 2015
    Quote Originally Posted by xmmancharl View Post
    Charl
    OK
    So not just me then.
    The manual is no help either.
    I have the upper switch set to the higher number range and set on the 10 between 6 and 5 on the dial switch shown.
