Forklift work platform
Results 1 to 25 of 26
    Aug 2015
    Easy build for a forklift work platform. I've been using a pallet for a work platform but this looks like an easy build. I would change the railings to a tube in tube to hold the side rails. It looks like they put a hinge on the bottom to fold down the sides for easy storage. I'd also use a channel iron on the bottom for the forks.
    Has anyone built one of these?
    Name:  Man basket.jpg
    Oct 2011
    Elkhorn, WI
    Re: Forklift work platform
    A place I worked for had one till the new Safety guy said OSHA wouldn't let us use it as the guy in the cage has no control of his destiny (ie: lift driver has a heart attack or passes out).
    Aug 2015
    I don't like to be in that situation either, but you have to trust the driver with your life either way. It is safer than standing on a pallet to change light bulbs 20 feet in the air.
    Oct 2007
    Vandalia, Ohio near Dayton
    OSHA will frown mightly on your plan. Better to rent a scissors or bucket lift for a day to do the job. OSHA will have at least 10 reasons why you shouldn't do what you're contemplating. 2 or 3 of them are likely good reasons because someone else has been killing in a home-made manbasket on a fork lift.
    If OSHA isn't a factor in your situation, I'd make the rails at least 42" tall, add a toeboard to keep the tools in the basket, add a way to chain the basket to the forklift mast, an anchor point for a fall harness, and a coil of rope to use if you need to escape from the basket when it's 20' in the air. I'd also get the hydraulics checked on the forklift because if the mast or forks drop with you in the basket you're going to be very unhappy.
    May 2012
    Ontario, Canada
    OSHA has published specifications on what then need to be to comply
    Jul 2014
    Bulldog Heaven at the end of my chain
    We have a couple by Vestal mfg. and they work well. The mast is guarded and there is a toeboard around the perimeter. Also a latching swing gate on one side. It does chain to the mast also.
    Slob
    Purveyor of intimate unparalleled knowledge of nothing about everything.
    Oh yeah, also an unabashed internet "Troll" too.....
    Aug 2008
    Built one this Fall, and it's worked out very well so far. We've saved thousands on tree trimming bills.
    I built to OSHA specs, and built quite a bit heavier structurally.
    42" rail, inward opening door, 6" toe boards all sides. Robust safety restraint to hold the doggone thing on the loader.
    I trust my loader operator. She tells me she loves me
    I do NOT really fully trust the hydraulics, and have looked into putting hyd. fuses on the lift cylinders. Problem is.......all the folks I've contacted need to set the things at the factory, and can't guarantee that they won't make the loader functionally inoperative due to restricted flow rates under normal operations. It would be a trial by error thing, which could get very expensive.
    http://www.farmersamm.com/
    Dec 2012
    Valley City, Ohio
    This is one I built couple years ago that works well for me. I know it needs a toe kick.
Size:  18.1 KBName:  IMG_1527.JPG
    Feb 2016
    Myrtle Beach
    Here's one I built a few months back. OSHA isn't an issue for us but I followed OSHA guidelines and it is definitely better than standing on a pallet which is what we where doing. Over built it a little but that's because I used materials I had laying around.
Size:  82.8 KBName:  IMG_4825.jpg
Size:  99.6 KBName:  IMG_4826.jpg
Size:  101.0 KBName:  IMG_4827.jpg
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    East Tennessee
    Should chain it to the mast. I'm not really up on osha regs pertaining to this but last summer while taking osha10/30 I found out that since my millwright days osha has for the most part outlawed man baskets that hang from a crane. The Big Blue accident in 1999 at the Milwaukee Brewers stadium had a lot to do with this. Although basically outlawed there is provisions that in the event there isn't any safer way to perform the necessary work in a life or death situation a basket could be used. Wish I had a dollar for everytime I worked out of a hook suspended basket or one on a forklift.
    Feb 2016
    Myrtle Beach
    Yes mine has chains also those pics where just taken before they where put on.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by 69sa200 View Post
    What’s fun is to be in one of these, when the crane operator free falls you 50 to 75-feet.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    East Tennessee
    CEP those are basically illegal now days.
    Feb 2016
    Myrtle Beach
    Never hung from a crane in one of those but I've hung from the top of a rocking sail boat mast in one a few times. Crew on the deck controlling the windlass to raise and lower me.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by Showdog75 View Post
    Yeah, I’m very old. But they were fun to work in! Same with these spider staging.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Mar 2015
    We use one all the time but if there are no controls on the basket the operator has to stay in the operators seat osha said it had to be pinned not chained has to have a capacity painted on it and you have to have it pre engineered not a copy of some one else's basket . Also you have to have attachment points for a harness .
    Feb 2016
    Myrtle Beach
    Where did OSHA require the pins to be? Mine has pins that go through holes in the forks that we also use for trailer balls. I added chain because I read somewhere that they shouldn't be attached to forks only.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    Nov 2010
    VA
    I think I still have a Bosun's Chair around here somewhere, possibly a Klein? I looked at it earlier this winter with an eye towards tossing it, but not sure whether I did or not. Anyway. A crane-suspended manbasket is something I've spent a great deal of time in, sometimes in confined-space entry jobs. Now that I'm a one-man show all of that silliness is hopefully behind me.
    Applied Fabrications, LLC
    Mobile Welding / Mechanical Repair in VA's Piedmont & Shenandoah Valley
    Hellinois
    Nope. You can see them all day long during summertime in downtown chitcago. Guys swinging around in those Bosun chairs, cleaning the windows on the sky scrapers. I figured they must make great money............nope. I think around $16-$20/hr. They're nuts!
    "Stick-man"
    Nov 2010
    VA
    You say that, but being Sticky Bond 008, I'll bet you've used them to check out my stuff....
    Oct 2011
    Elkhorn, WI
    AH! You ain't seen nothing until You are working on a small Independent Family owned Oil Lease in Pennsylvania. The crown pulley on the service rig needed greasing, they bring the hook down, knock the head off from a Pick(Mattok) to stick through the hook which you straddle while riding the cable back up to the crown! Been there, Done that!
    May 2010
    Port Orchard, WA.
    drujinin something like this?
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Mar 2015
    Capt B. They told us it needed to be pinned to the mast we made clamps with some ears on it that clamped to the 4 inch square tubing put ears on basket that slides in lines up. We are using it on a Pettibone super 20 with 6 foot forks
    Feb 2016
    Myrtle Beach
    Leogl thanks that makes sense. I'll look into that.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
    Oct 2011
    Elkhorn, WI
    CEP, Similar feeling! HAHA!
