Log Splitter Sanity Check
Results 1 to 25 of 37
    Feb 2012
    Jacksonville, FL
    Hi all. Getting ready to weld this up and I wanted to do a sanity check.
    It's a 8" beam with 3/8" thick flanges. Push plate is 1".
    Are there any glaring errors before I weld this thing up?
    Do I need to preheat the thick stuff first?
    Do I need gussets on the push plate besides coming off the ram? Does the back side ram support need perpendicular gussets?
    Jan 2006
    In A Nice Comfy Chair
    Re: Log Splitter Sanity Check
    Leave at least a inch before contact with the wedge and put some welds that stick up about 1/4" on the push plate for wood traction.
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Feb 2012
    Jacksonville, FL
    I have 25" from the slide to the wedge. It's a 5"x24" cylinder so that was my 1" clearance. Sufficient?
    Jan 2006
    That would work...
    ...zap!
    Do not attempt.
    Port Orchard, WA.
    I’m sure you will be fine. Only thing that would have been just a little better. Notch out the top flange, and web of the beam. And insert the wedge to the bottom flange, then weld all the way around.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    May 2012
    Albany NY
    Looks pretty good from here. Preheat is likely not necessary as long as your not trying to "cheat" using too small of a welder
    Nov 2006
    I would say ditto the anchor at the cylinder's cap end.
    Too bad there isn't a heavier beam available now... especially the 3/8" flange seems like it may be on the light side.
    Anyway, because of the unknowns of how this thing is gonna groan flex and twist... I would suggest to think about moving the cylinder back so that its cap end is near the end of the beam. That would allow fitting a long vertical anchor that could be tied to the web of the beam. Or is that space reserved for other components?
    Of course moving the cylinder back would leave a "tail" of the beam beyond the wedge. The tail can be cut off later. Meanwhile, after a test run it may be decided to move, strengthen, or modify the wedge's design... having some extra beam there may make that easier. All IMHO, of course.
    As to the push-plate, my guess is that there's gonna be enough power potential here that the overhang of the push-plate -even though it's 1" thick- could be bent by a tough log that's not cut square and loads the push-plate up high. Maybe watch that in action and reinforce as needed.
    Before some cut one themselves, on them, round over all those sharp (square) outside corners.
    ESAB Migmaster 250
    Hobart Ironman 230
    TWECO Fabricator 181i & 211i
    Multimatic 215
    Handler 125EZ
    Maxstar 150 STH - very nice
    Apr 2008
    NW ON Canada
    I absolutely love projects like this.
    I'd be looking at welding in a few "D" shaped stiffeners into each side of the beam between the top and bottom flanges. One on each side toward the base of the cylinder and another set of stiffeners toward the wedge. If you want to go all out, another set in the middle. Weld the stiffeners all the way around on each side.
    This will take all the twist and flex out of the beam while the splitter is operating.
    Be sure you remove the red iron paint prior to welding. 7018 is your friend here.
    Jason
    Lincoln Idealarc 250
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Thermal Arc Hefty feeder
    Torchmate CNC table
    Ironworkers Local 720
    Feb 2012
    Jacksonville, FL
    I did have intentions of boxing the beam in under the wedge and at the rear of the cylinder.
    I have a miller 252 that I'll be using.
    I appreciate all the responses guys.
    Port Orchard, WA.
    Few years ago, I built this splitter for my brother-n-law. He had to buy the PTO hydraulic pump, and some hoses. Everything else came out of my scrap pile. He has 20-acres of oak trees in California.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Dec 2009
    Stevens Point, WI
    I worked on one of those I-beam splitters once. Had to weld up a new wedge and fix the slide. The I-beam was all bent up from binding because when the slide binds up the ram tries to rotate the slide not push it along smoothly.
    Dec 2011
    You didn't say what you were going to use for hydraulic power. If you are using a bobcat or tractor then think about making it an inverted log splitter. That has the ram and wedge on the bottom, This lets you operate it from the seat of the bobcat, split wood on the ground without having to lift it, even use the splitter to load the pickup by starting to split but then lifting log and finishing split over truck/trailer, dropping the split pieces into the truck bed. This makes splitting a sit down job and gloves off split and load truck.
    Feb 2012
    Jacksonville, FL
    This is going to be a towable unit. I have a 15hp engine and 22gpm two stage pump
    Sent from my SM-G920P using Tapatalk
    Dec 2011
    Not sure what you are going to split? my experience On California gnarly Oak and Madrone you do not want "traction " on the push plate.The wood has to be able to move.If it cannot with the power you are generating something else will move. I would also gusset the push plate from the top corners to ram plate. Do not have the ram clevises to tight they need a little slop to account for slight binding. Mine was RR iron with less power generated and it still bowed.
    If you are only working with soft wood forget the above
    Doing the best I can with what I got
    Feb 2012
    Jacksonville, FL
    Quick update on progress:
    Boxed in under the wedge and the rear pin
    Welded up the slide
Size:  53.3 KBName:  20170113_123151.jpg
    Feb 2012
    Jacksonville, FL
    Another question. In this picture the weld is vertical, but when I was doing it I rotated the beam on it's side so I was welding the outside of the boxing in horizontally. On almost all of these in this position turned out pretty crappy. What is the best gun position to be in for a horizontal weld for a outside corner. It is 1/4" material.
    Port Orchard, WA.
    Quote Originally Posted by Ryanjax View Post
    That is something that is very hard to explain with the type written word. A lot easier to show you. In time you will learn, soon as you start you watch the puddle, and make corrections instantly.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Apr 2008
    NW ON Canada
    For me, I would have did it with 7018 stick. Because I know I can make nice welds in all positions with it.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    I'm not sold on the 3/8" naked I beam. Mine has a 1/2" thick plate welded to twin I beams side by side. You'll want some triangles to strengthen the push plate, and rear cylinder mount. I would have a frame around the cylinder just behind the beam slide to support the cylinder from folding itself when extended.
    I used a row of 1/2" nuts welded to the push plate to prevent a block from kicking out. A 15 ton I built in 1982? I was testing by cutting a 10" birch in half crossways. It was very green, in June. The bark slipped off. It squirted up, hitting me in the face. Tore my nose away from my face at the top, and I had six cracks in my skull radiating from the open hole where the nose should be.
    Now, barely a scar, but it doesn't flow air as well as it should.
    Willie
    Oct 2011
    Hamlin, NY
    Ouch.
    But the question is, did it knock some sense into you?
    Ryan
    CK WF1 TIG wire feeder
    Miller Spectrum 375 Xtreme
    Optrel e684
    Miller Digital Elite
    Miller Weld-Mask
    Quote Originally Posted by xryan View Post
    Ouch.
    By the time the headache subsided, I was a more cautious man.
    Willie
    What's the piston diameter, and maximum pressure? I want a heavier filet, on the rear cylinder mount, and I'd add 1/2" plate down both sides of the wedge to give more opportunity to secure it to the beam. A wider wedge would also take advantage of the two short levers you form almost instantly as a chunk begins to split. A narrow one must slice the full length of the chunk not much mechanical advantage. Overlap one side, weld, then cut with acetylene to form the edge. Finish with a grinder.
    40 years from now, you won't say "I wish I hadn't done such a thorough job of welding."
    Willie
    Feb 2012
    Jacksonville, FL
    Making some progress
  25. #25
    Feb 2012
    Jacksonville, FL
    Log lift and paint and it should be done.
