How did he get these colors in his welds?
Results 1 to 8 of 8
    Jan 2015
    Ohio
    Found this on Pinterest and I'm assuming the art has been tigged. But how did he get those colors and control where they went?
    Dec 2016
    Re: How did he get these colors in his welds?
    Heat and penetration.
    Nov 2012
    South Texas
    If you wash over stainless without adding wire you will get those colors.
    Oct 2007
    Vandalia, Ohio near Dayton
    The color comes from oxygen reacting with the the metal surface when the surface is still hot. This can happen accidentally by allowing air to contaminate the shielding gas while welding.
    I think TimmyTIG is right. The artist heated the material using a TIG torch, without adding filler metal, and allowed some air to contact the metal while it was still hot. The temperature of the base metal determines the color of the oxide film formed.
    There are some artists doing this with Titanium to make some wild colors on jewelry.
    Nov 2014
    PDX PNW
    That little guy at the bottom is sweet, any idea how much they go for, a Hundo maybe?
    Jan 2015
    Ohio
    Very interesting. So he probably completely built the piece first, then used the torch here and there at different temperatures.
    If heat determines the color, how did he go from base metal to yellow,orange,red in one place and then in another place go from base metal to light blue then dark blue? I'm wondering if he applied some sort of coating that changed the color sequence.
    @motolife313
    He sells some stuff on Etsy. He has a Darth Maul face on there for $199. He's a 23 yr old engineer from Chicago - Richard Lauth. https://www.etsy.com/shop/JackWeld?z...ontent=2147023 More at: https://creativitism.wordpress.com/2...the-metal-man/
    Nov 2012
    South Texas
    At the start of the bead where the metal is the coolest, you get a platinum like or silver color. As the metal heats up, the color changes to blue. It all depends on the temp of the base metal what color you get.
    Jan 2008
    Richmond, Virginia
    One might get one of those little tiny Smith O/A torches (Little Torch) just to put the finishing touches on an art piece. Might be a little easier to see and control color. Just a thought.
    I'm still trying to figure out this guy's technique for a finely crafted art piece.
    Name:  by johan art.jpg
    Name:  b y johan 2.de..jpg
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
