12volt to 110/120 volt inveters
Results 1 to 24 of 24
    Jan 2015
    Hamilton Ontario Canada
    Having problems setting up a battery backup system for my furnace. Have 2 large 12v battery's connected to my inverter connected to my furnace. Furnace error code is open ground or reversed neutral. I checked the inverter shows open ground even with the ground connected to the grounding stake and water pipe!
    This is the second inverter I got took the first one back, second one the same problem. This is a full sign wave inverter because the furnace will not run on my modified sign wave inverter! Any Help out there?
    Welders: IdealArc AC/DC 250
    Lincoln AC 225
    O/A torches
    Lots of Hammers and Clamps!
    Upstate NY
    Re: 12volt to 110/120 volt inveters
    The inverter's neutral is floating vs. building ground.
    In a properly operating building electrical system ground and neutral are electrically identical. The difference being neutral is the normal return path and ground is the backup/safety path when things go sour.
    Until and unless you get an inverter that allows tying neutral to ground (grid intertie system) you are looking at lots of frustration.
    Research "neutral-ground bonding" associated with portable generators when used in portable applications.
    Welders:
    2008 Lincoln 140 GMAW&FCAW
    2012 HF 165 'toy' GTAW&SMAW
    1970's Cobbled together O/A
    Jan 2015
    Thank You Mike837go. Not what I wanted to hear but puts me in the right direction. Any ideas for an Inverter? this is getting to be a nightmare! :mad
    Lincoln AC 225
    O/A torches
    Oct 2008
    New Jersey (yeah it sucks)
    1:1 Isolation transformer; tied in at the main panel.
    west texas
    You may need a split phase 120/240 volt inverter to get a 0v neutral.
    Problem is most 120v inverters is they run 60v on the hot and neutral, even on the expensive pure sine ones.
    Only problem is the cheapest one worth a damn is over $2,000.
    You would have the same problem if you were using a 120v only producing generator.
    old Miller spectrum 625
    Lincoln SP-135 T, CO2+0.025 wire
    Craftsman 230amp AC/DC and WP-18V torch
    Craftsman 100amp AC/DC and WP-17V torch
    Century 115-004 HF arc stabilizer
    Home made 4 transformer spot welder
    Home made alternator welder
    Jan 2015
    Mad Welder The generator produces the same problem it produces 220V but will not run the furnace! but not an inverter generator! Ouch at $2000. that being US$ equal to $3000 CDN$
    Lincoln AC 225
    O/A torches
    Jan 2015
    Billdacat Interesting I have a 1 to 1 transformer may try that! Thanks!
    Lincoln AC 225
    O/A torches
    Nov 2012
    Quote Originally Posted by Ypop View Post
    Any Help out there?
    My backup is an old fashioned wood stove! Yes. Even in Florida.
    You DO realize that motors draw SEVERAL times their rated amperage when starting don't you? And I'm guessing that your furnace requires 220/230 VAC. That means that your amperage draw from TWO 12V batteries is going to be at least 10 times what the furnace draws! Even after the motors have started. Long story short, you would need a MASSIVE inverter to start and run your furnace and you'd need a room full of batteries to operate it for more than a few minutes. This is not a good application for an inverter! Buy a generator instead. They will also cope with the start up current much better than an inverter will.
    This would make a great excuse to buy a new Miller Bobcat or Trailblazer!
    Los Angeles
    generator probably has floating neutral as well, if it is giving you the same error code.
    MM211 (Sold)
    Miller 125c Plasma 120v
    west texas
    You would need a bonded neutral-ground 120/240v generator, then unbond the N-G connection for home tie in.
    Nearly all of the smaller generators that only produce 120v power do not have a 0V neutral.
    An isolation transformer could work.
    I put installed my 100,000btu per hour high efficiency condensing natural gas furnace a few years ago, it actually only needed 120v power. I figured as big as it was it had to be 240v. Good thing I read the owners manual before installing it.
    Jan 2015
    Thanks Beoccoli1 that is what I figured too Know of any way around it?
    Would like to just be able to run generator I thought the inverter would be a work around but no go!
    FlaJoe Furnace is 110V ac full load even start up is 5 amps no AC not needed much up here in Canada maybe one month a year so just suffer through it and yes have a fireplace but have to keep feeding it where as the natural gas keeps coming in!
    Lincoln AC 225
    O/A torches
    Bemidji MN
    At Dad's old house we just had a plug on the furnace. Then when plugged in to something else the house wiring was unaffected.
    I did the same for my wood stove blower. Just unplug and plug in to something else.
    Will that work here?
    Airco 300 - Syncro 350
    Jan 2015
    Sadly No Minnesota Dave furnace is computer controlled for high efficiency but not for running on generators!
    Lincoln AC 225
    O/A torches
    Upstate NY
    For the genset (and possibly for the inverter) use the other 120VAC receptacle and install a G-N bonding plug.
    You'll want to do some more reading on what this accomplishes BEFORE you use it with the inverter. The Genset should be OK with it.
    Welders:
    Bemidji MN
    Right, plug it in to the inverter set-up.
    That way it is not tied to the house.
    Jun 2009
    Draper, UT
    My inverter genset (Yamaha EF3000iSEB) has a separate terminal on the front that is supposed to be tied to earth ground any time the machine is used (I never do though)
    MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45
    "No matter where you go, there you are" [Buckaroo Bonsai]
    Upstate NY
    Quote Originally Posted by frieed View Post
    Short of OSHA compliance, none of us do.
    However, G-N bonding has to take place somewhere in a business or residential electrical system. In a house or commercial building, the main panel has the bonding. A portable genset (or inverter) powering an appliance or tools over extension cords, will have to have the bonding added.
    Welders:
    Los Angeles
    Silly CYA instructions and does not Bond The N & G.
    MM211 (Sold)
    west texas
    Generator sets that produce 120v power only, typically your smaller ones have the floating neutral and no neutral ground connection.
    Larger portable contractor 120/240v generators usually always have the neutral ground bond.
    To properly tie in a generator it needs to have the neutral ground bond removed, so that neutral current doesn't flow through both the neutral and ground wires to the generator.
    But you are supposed to have a neutral ground bond on these generators for stand alone operation.
    If it is 120 volts you have to take the neutral from the inverter and make sure you land it on the L2 not the L1 or you will get that code, even using city or municipal power you will get that code.
    Sincerely,
    William McCormick
    Inverters are supposed to be internally neutral bonded by code.
    Sincerely,
    William McCormick
    Jan 2015
    ok got the furnace sorted out Thank You Every One!
    This worked for the inverter and probably for the Generator as well seeing as it works for campers with the same problem!
    Lincoln AC 225
    O/A torches
    Los Angeles
    Yup
    Good to hear it's all working.
    MM211 (Sold)
    Los Angeles
    This confooses the ground neutral bond purpose.
    On a generator, the frame is really the "ground"- when ground is mentioned it is not always Mother Earth.
    Driving a ground rod on a generator does NOT bond the Neutral to "ground".
    Clear as mud ?
    MM211 (Sold)
