Lincoln SA-250 project - Page 8
Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 176 to 200 of 285
  1. #176
    Dec 2016
    Re: Lincoln SA-250 project
    There is about a 1/4" drop below the top of the frame.
  2. #177
    MS
    Thank you sir!
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
    The only constant in life is there is never enough chains
  3. #178
    Dec 2016
    Anytime!
  4. #179
    Feb 2016
    Myrtle Beach
    Looking good hope you get it running soon.
    Lincoln 350MP
    Millermatic 350P
    Syncrowave 250
    1969 SA200
  5. #180
    Dec 2016
    Hopefully got a buddy coming out Sunday.
  6. #181
    Dec 2016
    My battery + is grounded here, is that accurate? Right side of the machine to the right of the leads ground bolts? Negative is grounded to the frame near the carb, below it.
  7. #182
    May 2015
    Basic electricity (+) positive should not be "grounded" anywhere, unless you have an old British sports car or Dodge with "Positive Earth" but then the (-) negative side is not grounded.
    Basically one side of the battery goes to ground the other does not. That it the definition of a short circuit, where the electrons go from one side of the battery to the other without going through the load.
    Sent from my SM-G935P using Tapatalk
  8. #183
    MS
    Are your colors still correct on your wires? Where does the yellow wire go?
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
  9. #184
    Dec 2016
    Honestly man, I'm in school right now so I couldn't tell ya. I just don't want to burn out all my wiring by grounding the battery grounds to the frame in the wrong spots like you told me so I've been thinking on their locations.
  10. #185
    Dec 2016
    A couple days late, but I Got a perfect picture taken with my Perfect Valentine of the year!
  11. #186
    MS
    Good deal. I hope your friend comes by and helps you get it running soon. By factory wiring that yellow wire goes from alternator to temp. gauge I think unless something is mixed up. Only other yellow on mine goes from PC board to idler switch. We have different engines though and being used, you never really can count on anything without being able to see it or ohm it.
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
  12. #187
    Quote Originally Posted by jerry1700 View Post
    What a cute lookin' couple.
    Save 2nd Base!
  13. #188
    Dec 2016
    I hope so too, ha. Thanks man! @Blocker & Hahah yeah she's definitely a keeper, Duane!
  14. #189
    Dec 2016
    Officially passed my mig cert test, now I'm back where I belong, burning rods.
  15. #190
    Dec 2016
    Been a month and a half since I've burnt a rod, so I'm not gonna complain, but definitely lost a lot. Vertical up 1/8" 7018 @ 95A
  16. #191
    Feb 2017
    Hmm, why am I not seeing most pics posted by Jerry? at least the last couple of pages worth.
    Proud 110v club member
    Hypertherm 30xp - like it so far
    Hobart 140 - bought in 2005 - love this thing
    Miller Thunderbolt ac/dc
    HF 14" chop saw bought in 2014 - passable (wobbles)
    HF 4x6 bandsaw bought in 2005 - OK but slow
  17. #192
    Dec 2016
    Maybe not loading?
  18. #193
    Feb 2017
    Yeah I see them now after restarting the browser...much better! Also, great job with the SA-250 rehab project!
  19. #194
    Dec 2016
    Thank you! I've got a lot more painting to do, obliviously, after I get it running again. Then put on new wires and grounds. I just want to get it running first. Then do a wire restoration, wire by wire.
  20. #195
    Dec 2016
    The signal wire from the start button goes to the R terminal or S terminal on starter solenoid?
  21. #196
    Dec 2016
    All grounds are great and in working order.
  22. #197
    May 2015
    The start button connects to the "S" terminal on the solenoid.
  23. #198
    Dec 2016
    The problem has been solved. My wiring has been right this entire time, the problem was the R terminal on my starter has gone bad.
  24. #199
    May 2015
    I'm pretty sure the "R" terminal isn't used in this application the "R" usually goes to a relay or bypasses a ballast resistor for the ignition coil.
    You should just have the large cable from the battery positive and the one wire from the starter button to the "S" terminal.
  25. #200
    MS
    That is great that you got it figured out! PICTURES! WELDING! VIDEO!
    Lincoln SA-250
    Lincoln SW 200
    Miller Thunderbolt
