Miller airpak
Results 1 to 13 of 13
Thread: Miller airpak
    laguna niguel, Ca USA
    Miller airpak
    Looking at a 1997 miller airpak has the optional 3 phase gen 10kw/15kw waiting on ser# from seller 6000 hours said to be in good working order for $3500 obo and ready to goto work any cons to this unit ? Other then the stator being obsolete on some but can be modded
    Thanks for any input
    I was looking at a trailblazer 325d prior
    And don't like that the 302airpak was gas and this is diesel
    Sent from my LG-K550 using Tapatalk
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Smith Gas Mixer AR/H
    Tig is my Kung Fu
    Throwing down dimes and weaving about
    Instagram http://instagram.com/weldor_wes
    WeldorWes@WcWeldingLLC.com
    Sep 2005
    Cave Creek AZ
    Re: Miller airpak
    A gas engine drive with 6000 hours? Wow, lots of money for an end of life machine.
    Re: Miller airpak
    Its diesel
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Tig is my Kung Fu
    Jan 2011
    Hutchinson Kansas
    Re: Miller airpak
    Sound like a great deal. That's pretty much what I'm looking for. Big enough for carbon arc gouging with its own compressor and a 3 phase generator big enough to power the shop when the lights go out.
    Re: Miller airpak
    Quote Originally Posted by propanehotrod View Post
    Yah my needs are the same but my shop is mobile it will be here weds next week going to have to modify my bed to make it fit with enough ventilation or just raise it up in bed. I have 30 inches width in the bed with sides being 30 inches high and length being 8 ft
    I talked with my local miller repair facility with the serial number and they said they have all parts needed available. And got pricing on a few things iirc screw compressor rebuild,cv board and main boards so I had an idea on repair costs that will come up and I'm still under anything else I was finding cost wise
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Tig is my Kung Fu
    Re: Miller airpak
    If that unit has a wet compressor. make sure you put the right oil in it or you can kill the compressor.
    We have rebuilt several because of the wrong oil.
    Re: Miller airpak
    Good to know thank you will look into it
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Tig is my Kung Fu
    Re: Miller airpak
    Well got the miller airpak the compressor is part of the motor looking to possibly need the rings replaced going to go thru the check valve and unloader assembly and see what is going on only building 60 psi and need to chase down the wiring on the low idle relay
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Tig is my Kung Fu
    Western, NY
    Re: Miller airpak
    First thing to check is the fuse and fuse holder. I had a fuse holder go bad on mine a few years back. They are a standard fuse holer you can get at a parts store.
    When you get into the air end parts they seem to cherish them immensely.
    Re: Miller airpak
    Quote Originally Posted by theweldor View Post
    Fuse holder is good
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Tig is my Kung Fu
    Western, NY
    Re: Miller airpak
    There are 3 wires to that coil. One is ground, one is a pull in coil, and one is a hold coil. There's a relay on the engine side of the firewall between the generator and engine that switches that circuit. If both of those are good, short of a bad wire, the idle controller would be the issue. It is located behind the front control panel. If that needs changed it is set in some heat sink compound to keep it cool.
    Re: Miller airpak
    Then what's the other 2 wire one for. What i really need is what number wire goes where on the 2 relays. Cr99 an cr2
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Tig is my Kung Fu
    Re: Miller airpak
    the solenoid on left is what I'm talking about which is controlled by cr99 the solenoid on the right is the fuel solenoid its working like it should I think it turns fuel on when turned to run and off when switch is off I'm finally got a new vom since I lost the one I had when they stole everything and am going to test the idle controller behind the face of the machine
    Miller Xmt 350
    Lincoln Ln-25
    Ahp 200x
    Tig is my Kung Fu
