Ironton Dry Cut Saw - Page 2
Results 26 to 41 of 41
    Re: Ironton Dry Cut Saw
    Bonzoo does WD40 fling and cause a mess on the saw/workbench. I can't help but wonder if it would get into the bearings on the motor and cause shortened life cycle for the bearings.
    Tony, NOT being a smart a$$ but WD 40 is sold as liquid too besides the spray. Harbor Freight sells it . http://www.harborfreight.com/wd-40-lubricant-62232.html Only: $22.99 That's a one gallon can.
    I knew that Bob. I had just forgot about that probably because I don't use it often enough to ever buy it. That may change or may stay the same. Thank you for reminding me
    ESAB REBEL EMP 215ic
    L-tec PCM-DVi 40A plasma
    Victor Performer O/A
    Lincoln Viking 4C 3350
    Feb 2017
    Atlanta, GA
    Im not impressed with my ironton yet. Cuts are uglier than abrasive cuts minus the burrs. I wonder if its just the blade... maybe i should get a diablo or morse blade or something...
    Everlast Power MTS 200
    Chicago Electric Plasma Cutter
    Slugger Mag-Drill
    Ridgid 14" Chop Saw
    Several Grinders
    Several Benders
    Forge, Leg-vise,& Anvil
    Several Oxy-Acetylene and Oxy-Propane torches
    13" 16 Speed Floor Drill Press
    To name a few..
    Feb 2014
    n.w. of chicago
    Quote Originally Posted by MetalHeadJason View Post
    Yeah he still uses terms like heliarc and stuff. He hasnt done any metal work in years
    Sounds like he done metal work before you were born don't make it right but you used to turn your blades around on circular saws and chop saws to cut aluminum and steel wasn't the best way but it was the only wway and it is heliarc from the get go don't knock your elders they used to weld without crutches
    Feb 2017
    Atlanta, GA
    Quote Originally Posted by pat h View Post
    Im not knocking him. I think its badass he used to do that. He just hasnt done any work in ages. Heliarc is just a brand now. He didnt know what tig was haha he kept talking about metal inert gas too and i told him the proper term now is gmaw...
    Im gonna put my ironton to work today. Hopefully i get better results this time...
    DO u guys think its just the crappy blade that came with it?
    Slugger Mag-Drill
    Ridgid 14" Chop Saw
    Several Grinders
    Several Benders
    To name a few..
    Jan 2015
    Bellingham, MA
    Like I showed earlier in the thread, mine cut 1/4" thick steel like butter
    Feb 2017
    Atlanta, GA
    Quote Originally Posted by Smartdave View Post
    its not that it doesnt cut, it cuts fine but not as nice and smooth like a makita dry cut saw
    Slugger Mag-Drill
    Ridgid 14" Chop Saw
    Several Grinders
    Several Benders
    To name a few..
  8. #33
    Not there
    Bust out the wallet. NOTHING cuts like a Makita "dry cut" ? LC 1230......especially if there's a Tenryu stabilizer riding its shaft.
    The Morse saw is close. I have one too. The 12 has less vibration. Simple engineering math there.
    OK My Scotchman cold saw cuts "better" than either but I'm a welder, not a machine shop. I dont need tenths. 64ths are fine
  9. #34
    Feb 2017
    Atlanta, GA
    I am a scotchman hah. But ill look into it
    Slugger Mag-Drill
    Ridgid 14" Chop Saw
    Several Grinders
    Several Benders
    To name a few..
  10. #35
    Mar 2017
    Forest Grove OR
    I have a Dewalt dry cut, the cut capabilities were impressive, but the quality a lot lower than desired. I found the stamped steel base was deflecting too much, and the fence didn't hold true. I tossed the base and mounted the saw to a 5/8" thick plate of steel, about 14" x 20" (A scrap I had), and welded a 3/8" x 4" angle back fence to the base. The added mass and thickness of the base, and rigidity of the welded fence vastly improved the cut quality, and that also increased the blade life by about 3x's. It quit tossing carbide tips.
  11. #36
    Not there
    One other thang. Get the Morse V-block kit and make it fit. I use triple magnets milled into the back
  12. #37
    Feb 2014
    n.w. of chicago
    You just proved your ignorance it's gtaw, and a real dry cut saw works at 50 to 100 rpm
  13. #38
    Feb 2017
    Atlanta, GA
    man, im very unhappy with my ironton drycut saw, the fence doesnt hold true and gets off progressively as it is used... thumbs down. I'm gonna probably return it and get an evo or morse or maybe makita, only thing is that makita has a small blade....
    Slugger Mag-Drill
    Ridgid 14" Chop Saw
    Several Grinders
    Several Benders
    To name a few..
  14. #39
    Feb 2017
    Atlanta, GA
    no metal inert gas is mig and the modern term is gmaw because most of the time active gasses are added...
    also the lowest ive ever seen a dry cut saw at was 1300 rpm. ive heard of some bigger saws that go real slow but i think fluids are added thus making it a wet cut. i could be wrong on that but not on the other topic of mig.
    what a dumbass.
    Slugger Mag-Drill
    Ridgid 14" Chop Saw
    Several Grinders
    Several Benders
    To name a few..
  15. #40
    Feb 2013
    I have a 14 Evolution dry cut saw. It is the most used saw in my shop. I use industrial saw blade wax on my aluminum cutting.
    Fly
  16. #41
    Hey Bonzoo is there any chance you could show a pic or two of how you have the magnets set in the back side of those Morse V-Blocks ? I'd appreciate it kindly.
