Ironton Dry Cut Saw
Results 1 to 17 of 17
    Jan 2015
    Bellingham, MA
    Ironton Dry Cut Saw
    After using my wood circular saw for the past year to cut all my aluminum, I have decided to finally buy a dry cut metal saw.
    I bought the Northern Ironton 14 inch saw.
    So far I have only cut aluminum with it, but man it just chews through 1/8 and 1/4 stock like butter.
    Nov 2016
    USA
    Re: Ironton Dry Cut Saw
    Nice buy Smartdave, that's next on my list.
    Jan 2015
    Bellingham, MA
    It's 299 and I found a $20 off coupon. And free shipping. I got to the point where I needed to cut Steel with something other than my wizwheel or plasma
    They work really good on pipe tube flat and angle.
    ESAB REBEL EMP 215ic
    Victor Performer O/A
    Lincoln Viking 4C 3350
    Oct 2013
    After a decent belt sander that's the next tool on my list! Not sure about what brand yet.
    How's the blade life? Can't imagine aluminum really effects it but im curious how many cuts one can get on 1/8" and 1/4" materials of the steel variety.
    Lincoln 210mp
    Lincoln SW200
    Jan 2015
    Bellingham, MA
    All the long term reviews I saw on YouTube praised the blade life
    I've had that same saw for almost a year. I'm really happy with it.
    Jan 2015
    Bellingham, MA
    I had some 2 inch x 3/16 thick walls. I decided to try and cut it. Totally amazed at how fast and effortless it was
    Jul 2014
    Smart Dave the easiest way to extend the blade life is always let the blade reach full speed before you start cutting .making contact with steel at low speed will shatter a few teeth
    Jody from WTT uses a bar of Irish Spring soap to lubricate his blade. Aluminum can gum up the blade if you don't use something on the blade to keep the aluminum from gumming.
    Jan 2015
    Bellingham, MA
    I always let the blade get to full speed before I start a cut.
    Good tip about the soap, thanks
    I have not used the soap trick personally just thought I would share the tip since Aluminum cutting was mentioned.
    Not there
    WD40 is the best AL lube hands down.Not too much.A little goes a long way.
    Bonzoo does WD40 fling and cause a mess on the saw/workbench. I can't help but wonder if it would get into the bearings on the motor and cause shortened life cycle for the bearings.
    Feb 2014
    n.w. of chicago
    Soap or candle stick all better than nothing wd40 or 30w bearings should be sealed any way there's purpose made cutting fluid for industry most wouldn't know the difference between olive oil or mobile 1
    Not there
    Sure does. Thats why I said "a little" You could apply with a cotton ball. Just enough to "slide the chip" to the side as it cuts.
    Soap might be good too. I have a bar of 6061 4 inch wide by 1 inch thick coming in for a belt sander build..I'm going to try it.
    I think WD will win.
    Aha I would not of thought to try that way of applying it. Thanks for the pointer.
