HF portable band saw no longer insulated
Results 1 to 14 of 14
    Aug 2009
    Trinidad
    My HF portable band saw is no longer insulated,
    if I am barefoot or touching the material/table being cut I get zapped by 110v.
    can this be fixed ?
    MM 180
    Jul 2014
    New York
    Re: HF portable band saw no longer insulated
    Sure... Find the ark or bad ground and fix it.
    Sent from my XT1254 using Tapatalk
    I am a new guy, please don't be to harsh.
    Welding Equipment so far:
    First Welder: Blue Hawk Flux-MIG 100 (no tanks, so only Flux for me right now)
    Second Welder: Miller MillerMatic 211 Auto-Set with MVP
    I have to ask, wtf are you doing cutting and working with metal with bare feet? Could be a problem with the outlet or cord as well.
    Jun 2011
    Aiken SC area
    Something doesn't smell right here. Bob
    Soda springs,Id
    It would be nice to know if he gets shocked while holding it or only when the trigger is pulled. Yes, I don't understand someone doing metalworking barefoot, even in Trinidad.
    Mike
    Hobart G-213
    If you guys had ever been to Trinidad you'd understand, lol most people are in flip flops, sandals, and a lot of people go barefoot. A lot different than here in the US
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Northern Cal., Shasta County
    High resistance neutral, open neutral (or no neutral ) along the way somewhere. It's using the ground which is tied to the case.
    Mar 2017
    Forest Grove OR
    Could also be that the ground you are standing on is the problem. I've experienced that when a building had a bad neutral and was pulling ground from it's ground rod.
    Check the plug, it should have good continuity (0 ohms) between the ground pin and the chassis of the saw. Next check the outlet, should also show very near 0 ohms between the neutral and ground lead. If not, it's a wiring problem.
    The problem may or may not be in the band saw. Check the building wiring too for stray voltage.
    "Hey! (Bum bum bum) Got any grapes?" (credit to:Bryant Oden in "the duck song")
    ---Meltedmetal
    Oct 2007
    Vandalia, Ohio near Dayton
    Quote Originally Posted by lennyk View Post
    can this be fixed ?
    Yes. Drop the saw in a convenient trashcan and go buy a new saw.
    Benson's Mobile Welding at your worksite or place of business. Serving Dayton, Ohio and the surrounding metro areas.
    AWS Certified Welding Inspector (#XXX10731) and Certified Welding Educator (#XXX1008E)
    I was at HF yesterday and they had all those band saws on clearance. There must be a reason why.
    Jan 2017
    Sacramento, Ca
    Right? Barefoot? D@mn hippies.
    Unless he's in Trinidad Colorado......
    Quote Originally Posted by Sandy View Post
    That's what I'm thinking. This shouldn't even be possible if the building wiring is according to US specs. YES, I know Trinidad isn't in the US! That (an added chassis ground) exactly why they added a third wire to US power plugs. OP, does the saw still have the three wire plug or has someone monkeyed with it? It sounds like you have a combination of bad wiring (open neutral?) in your building and a neutral to ground short in the saw. It also sounds like your building may have POOR grounding in it.
    The fault in the saw should be an easy fix but given Chinese construction, you have not be able to get the saw apart and then back together again!
