Fire Extinguisher on a skid
Results 1 to 11 of 11
    Where would you mount these? I want to put 2 of em on. One is a 20 lbs dry chemical and other is pressured water i can recharge myself bought these from a nice small business place. I have been lucky so far n now want to be more prepared Name:  20170614_214006.jpg
Size:  27.2 KBName:  20170614_214122.jpg
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    May 2007
    SoCal
    Re: Fire Extinguisher on a skid
    Where they are not in the way, and readily accessible.
    Job 28:1,2
    Danny
    Bemidji MN
    When people ask me where to put stuff, I say "someplace that makes sense"
    In this case, one on each side where they are not obstructed by anything else.
    Airco 300 - Syncro 350
    It seems like anything in front is in the way for quick n readily access only option is on top of oxygen cylinder but it will be a pain because the gooseneck trailer i normally set it on side ways n i thought ask around
    Oct 2013
    W. WA
    Find pvc pipe dia of extinguishers and make rack to mount (at slight slant) above cylinder (looks to be nice open space) and slide extinguishers into tubes (not using factory brackets).
    DB
    Nov 2013
    Livingston, New Jersey, United States
    Quote Originally Posted by tanglediver View Post
    I would just heavy tac them in place because where ever you put them you will wish they could were somewhere else.
    John
    Sent from my XT1254 using Tapatalk
    Quote Originally Posted by johnrbauer View Post
    John
    Quote Originally Posted by labparamour View Post
    DB
    You got a point there i might just do that
    Sep 2017
    best answer, anywhere that is accessible is okay
    Not near anything likely to catch fire. You dont want to have to fight flames to get to the extinguisher.
    Hobart Handler 190
    Syncrowave 250
    Purox Metalmaster
    Oct 2007
    Vandalia, Ohio near Dayton
    Mount or store them out in the open, where you can grab them and use them in an emergency. I always figured that if this made them vulnerable to being stolen, so be it. If it's locked up tight, it'll be too late by the time you get it out and ready to use.
    Benson's Mobile Welding at your worksite or place of business. Serving Dayton, Ohio and the surrounding metro areas.
    AWS Certified Welding Inspector (#XXX10731) and Certified Welding Educator (#XXX1008E)
