Cleaning up some mushrooms
Results 1 to 15 of 15
    Dec 2015
    Decided it was time to clean up some mushrooms on the ends of a couple of prybars. I was going to simply grind them down but then I thought why not use my new portable bandsaw and take advantage of the new stand I made and just cut them off.
    http://weldingweb.com/showthread.php...21#post8494721
    This is a photo of the first mushroom cap cut off
    The bottom side of the cut
    Then I went after the second mushroom cap and cut it off
    That crack was a big mess so I took off another slice which just broke apart during the cut
    Dec 2015
    Re: Cleaning up some mushrooms
    I wanted to get to the bottom of this so I took off another slice
    ...and another
    ..and one more to be sure
    Finally, no more cracks. But it was an interesting lesson and I'm glad I decided to cut off the caps instead of grinding them down.
    Here's a summary comparison
    Mar 2004
    I have been told about this hazard but never have seen a graphic example. It is a very good reason grind mushrooms before they become shrapnel.
    Oh, those mushrooms.... I totally misunderstood...in my defence it is Friday...
    Mount Tabor VT
    Once Mill stones ground grain into flour. The flat thing was easy, let them rub. The grooves that let the coarse grain disperse across the stones had to be cut. It was a highly skilled trade. Little bits of mushroom would fly off, embedding in the forearms, and hands, and face. As time passed, these became black spots visible under the skin. Before hiring, he would have to "SHOW HIS METAL". A lot of metal proved experience. I wonder what he did to protect his eyes?
    Willie
    Feb 2004
    TX
    That's interesting and kind of scary.
    Jun 2008
    Speaking of mushrooms flying.
    Quite a few years ago we used to rebuild engines in the shop, a fella was using a three jaw puller to pull the harmonic balancer of the front of a diesel, he had a good bit of strain on it, wouldn't move so he gave it a belt with a hammer. A piece flew off the end and severed an artery in his forearm, didn't just cut it, severed it. Looked like a water fountain spraying cherry Koolaid. It was quite an operation to fix as the artery retracted both ways when it was cut, he ended up with quite a gash on his arm.
    It was a new SnapOn puller so they were called and were told that the puller was faulty as it broke when hit. Nope, even tho the nut is chamfered like it was made to be hit, it's not supposed to be it actually said in the instructions not to hit it........................Mike
    Jan 2016
    A trick told to me by an old timer was to use some brazing rod and coat the tops of chisels or any bar you will be beating with a hammer, the softer braze will hold in any flying chips as it is softer than the steel and wont crack and fly off..
    Nov 2012
    new york city
    i prefer to grind my chisel/punch ends to shortening my tools by cutting. on my 12" chisel i slipped a 1" hex nut over the striking end and welded it to present a larger striking surface.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Upstate NY
    When I 'inherited' many strikeable tools from my dad, most were badly mushroomed.
    For a couple of years, I would stop a project to grind off the deformed metal before using the chisel, drift, etc.
    I haven't been hit by metal chips yet!
    The perminant damage to base of the left index finger is testimate to the accuracy of my aim with a hammer....
    Welders:
    2008 Lincoln 140 GMAW&FCAW
    2012 HF 165 'toy' GTAW&SMAW
    1970's Cobbled together O/A
    Apr 2016
    CA
    Very interesting and informative thank you for sharing.
    I like the add braze to the striking zone of the chisel tip Hobby
    '65 Lincoln Idealarc 250 AC/DC
    ESAB REBEL EMP 215ic
    L-tec PCM-VPi 40A plasma
    Victor Performer O/A
    Lincoln Viking 4C 3350
    Jan 2017
    Dallas, TX
    When the first sign of mushrooming happens, grind it off. Best to chamfer the ends a bit so they don't mushroom. I had a piece fly off a chisel and imbed in my hand like a bullet.....took surgery to remove. ALWAYS wear eye protection when hammering on anything.
    Sep 2017
    Thanks for sharing this hack. I will surely try to do this.
    Dec 2016
    raleigh nc
    Don't forget to check your hammers for cracks also . I have a piece of a ball peen hammer setting next to one of my ribs from changing teeth on a trackhoe bucket. Went right thru my shirt....
    Nov 2017
    I have a piece about the size of a broken off pencil tip behind my left knee cap.
    Beating on something in my teens and ended up rolling on the ground hanging
    onto my knee.
    Cripes that hurt.
    Went in the side right thru my jeans.
    One time later on in life I had to get my left knee x-rayed and the poor gal running
    the machine took the print and looked at it.
    Checked the metal box that holds the screen and then checked the bed I was laying
    on when the x-ray was taken.
    It is very visible on the prints.
    I told her about it after and she figured she was losing it.
