Cut my own driveshaft
Results 1 to 14 of 14
    Mar 2016
    North Georgia
    Tiny ain't it??
    I was also curious if I could post pics again since the crash.
    Blue stock- shopmaster, a/bp330, maxstar 150stl, maxstar 210, hf251, Tbolt ac/dc, mm 135
    Red stock-ranger 8, weldanpower 150, idealarc 250 ac/dc
    Esab plasma, Victor OA set, Air products ac/dc 400 amp
    It's me flipped in snow..doughnut fail
    Re: Cut my own driveshaft
    did you ever get that hardley toad running?
    by a resevior in north central ar.
    i had a 1966 dodge van that i had to cut the driveshaft after installing a long shaft automatic instead of the stick transmission. the drive shaft from center to center was only 14 inches long. i cut but had drive shaft co. weld and balance it.
    Jul 2014
    No carrier bearing in that extreme driveline.....
    Slob
    Mar 2016
    North Georgia
    I did. Actually been on it a couple times already. We had some super nice weather last week and it got some road time
    Mar 2016
    North Georgia
    I did take the shaft and had it balanced and trued up...they did the weld since they had to do their thing.
    Drove it home tonight for the first time with a th400 instead of a manual trans. Full manual valve body, 3500 stall, 3.73 rear axle.
    It's mean
    Soda springs,Id
    And be ready to change U-joints quite often.
    Mike
    Quote Originally Posted by Michael ray View Post
    Cool.
    You are in gods country as far as riding.
    Jan 2006
    In A Nice Comfy Chair
    I do driveshafts all the time.
    Get your mind out of the gutter.
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Mar 2016
    North Georgia
    Well...
    Shaft works well. No vibrations even in the 100 mph neighborhood
    I would be out in it or on one of the bikes if the weather were better.
    We have some nice days here but also have plenty of the soggy gray wet ones too...
    Back to the shop I suppose.
    Mike
    I assume the extreme angles are because the suspension is dangling down on the lift and that it isn't that bad when the weight is on it. I am wondering how long rear seals will last on the tranny tailshaft though. It seems to me the shortness of the shaft will keep the splined drive sliding in and out a lot more than usual.
    Mar 2016
    North Georgia
    It's still sweet.. the angle is nice when it's on the ground and well within acceptable maximum axle limits. Can't see in the photo but it has torque arm that I made for it, kinda like the 82-02 camaro had...
    The leafs keep it up, shocks help with hop and the torque arm keeps me from "S" shaping my springs when it's under a load.
    It's still pretty cool here but I fully expect it to pull the front wheels as soon as I can get the tires to hook.
    Last summer I got in trouble for doing a wheelie in front of the shop
    Apr 2018
    Daytona Fl
    Wow looks cool, but looks like tough angles. Hopefully you won't have any problems with universals , pinion bearing/seal and rear trans bushing and seal.
    Not there
    I'm guessing it's a bunch straighter sitting on the ground. Worse scenario is cut the perches and give it a li'l twist up.You can see where the seal rides on the output( I think ?).It straightens up a good bit.
