worth it??
Results 1 to 20 of 20
Thread: worth it??
    Oct 2016
    countryside of NY
    worth it??
    got a guy selling a welder.. 2400 bucks he came down to 1900 with 2- 25 foot leads. hey Minstoa Dave.. check out!!!! I dont know its worth buying it or go with ranger 9. this weldanpower G8000.. is an older gen just before ranger 8 came along..
    MM215
    Victor torch set
    Oct 2016
    countryside of NY
    Re: worth it??
    240 hrs sir
    MM215
    Victor torch set
    Sep 2015
    SE Pa
    Re: worth it??
    Hours?
    Oct 2016
    countryside of NY
    Re: worth it??
    240 hrs
    MM215
    Victor torch set
    Re: worth it??
    Meh...
    Soda springs,Id
    Re: worth it??
    Had a G9 I picked up cheap and it welded good but the Onan had internal problems I didn't want to $$ into so I sold it. It had CC and CV selections on it also.
    Mike
    Oct 2016
    countryside of NY
    Re: worth it??
    Meh...
    my thinking also!
    MM215
    Victor torch set
    Oct 2016
    countryside of NY
    Re: worth it??
    Mike
    yeah, that what I learned.. and I emailed to lincolin company.. Onan is known to have problems.. so I think best to pass along and save the money for a better one... wise judgement mla...
    MM215
    Victor torch set
    Re: worth it??
    My Miller Bobcat 250 has the Onan/cummins/robin/Subaru engine. It was such an embarrassment they changed names several times, but mine at 1500 hours is fine. When I bought it it only worked well with choke out a bit. I promised to tear it apart to see why, never did get around to. It seems to have cleared up.
    Bemidji MN
    Re: worth it??
    At $1900 I wouldn't really be considering it.
    Officially a <shoulder shrug> for me. Nothing really wrong with the machines that I know of - just seems high priced to me.
    I paid $1500 for my 400 hr. '94 bobcat 225nt and although I considered it a little high, it was all I found in quite a while in a reasonable price range.
    Airco 300 - Syncro 350
    NW New Jersey
    Re: worth it??
    I've had several onans over the years in tractors chippers, and stump grinders. They generally run good, have all the normal age related failures, charging, carburetor, ignition, etc. Its just parts are expensive, and a little harder to find. They generally have lots of torque but eat a lot of fuel. Does the machine do what you need it to do? that's the most important question. Does it a have CV or is it just DC / CC ?
    Oct 2016
    countryside of NY
    Re: worth it??
    it got ac/dc+/dc- and cv
    MM215
    Victor torch set
    Oct 2016
    countryside of NY
    Re: worth it??
    that how I feel, Dave,, tad too high.. I told the seller that you are based on ebay price which is unreasonable high most cases. in your spot.. 400 hr on a bobcat 225, 1500 bucks is not bad I am looking at the hours and overall condition..having that said.. I have factor in type of engine. that where going get tangle.
    MM215
    Victor torch set
    Soda springs,Id
    Re: worth it??
    The fault wasn't really because it's an Onan. It somehow ate a small screw or nut before I bought it cheap and hammered the piston so bad it egg shaped the bore. I don't use my Hobart G-213 that often but I feel confident it will outlive me with the Wisconsin 2 cylinder engine.
    Mike
    Jul 2007
    Lake Of The Ozarks MO
    Re: worth it??
    The deciding factor for me would be, how much generator power does it have?
    Then it might run other bigger things, if it had 8000 watts or so.
    I like the low hours. It makes the motor worth as much as the machine, which I believe is about $1,500 ish.
    Miller Dynasty 700
    Miller 350P with Aluma-pro push-pull
    Miller 280 Dynasty with expansion card
    Dynasty 200 DX
    Enuff power and hand tools to fix or create one of anything..... but mass produce nothing!!!
    Oct 2016
    countryside of NY
    Re: worth it??
    Quote Originally Posted by FusionKing View Post
    Yeah, i told the guy i offer for 1500. He said no then 1900 which willing to go for. I told nope, i changed my mind, then he got nasty foul mouthing looking for a fight. I hung him up. So much for that. I am just let flush down and carry on
    MM215
    Victor torch set
    NW New Jersey
    Re: worth it??
    He must have needed the money for anger management classes
    Oct 2016
    countryside of NY
    Re: worth it??
    Pretty much so
    MM215
    Victor torch set
    Oct 2008
    NorCal
    Re: worth it??
    Quote Originally Posted by irish View Post
    Well, come on now, she's a classic! You always get better money if it's a classic!
    Onan parts are expensive.
    You are certain to find better deals out there, and that seller is having trouble understanding market fundamentals!
    Miller Dynasty 350
    Miller XMT 304
    Oct 2016
    countryside of NY
    Re: worth it??
    Well said crab, yeah, a classic but an expensive motor to maintain. Yup the seller thinks getting a profit. Claims he spent 35 yrs as small engine repair tech. But he got no clue on history of these welders. Certainly a person to avoid .
    MM215
    Victor torch set
