Update to my welder Harbor Freight 170
Results 1 to 25 of 28
    I just purchase my 170 work great out box (Nov 2017
    But I did few improvements to extend life and function of the welding
    1) Add a stronger relay
    2) Add a longer ground wire 10FT
    3) New ground clamp
    4) Welding Cart
    The last crash of this deleted all photos for Nov 2017
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Re: Update to my welder Harbor Freight 170
    Great mods Dave.
    Appreciate it if you could you give additional info on the relay upgrade (why, parts needed, cost etc.)?
    Nice welding cart. I just bought the one at HF. Did you make it yourself?
    Mike
    See Amazon Dayton 5Z538 Relay, SPST-NO-DM, 4 Pins, 120VAC 30 amp
    The relay on welder looks like a 10 amp lite duty
    Yes I made the welding cart
    The ground wire I had with ground clamp
    Quote Originally Posted by MBG View Post
    Great mods Dave.
    Mike
    Note the drawing show for 240 volt coil I list a 120VAC that will not work
    IF you have a 120VAC it can be use by add one side of coil to the neutral (shown as the red wire)
    https://www.amazon.com/Dayton-5X851-...+240VAC+30+amp
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Here a photo of the relay use on the HF 170
    By size it looks like a 10 amp
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    May 2015
    Barre Town, VT
    I looked up the relay on the board a couple years ago it is a true 30 amp relay. Incase people are wondering.
    My "collection":
    Homemade Stick Welder
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Solar 2020 Plasma Cutter
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    It how long will last at 30 amps
    That why change to relay to Haevy Duty type it rated
    100,000 cycles at 30 amps and 1,000,000 cycle
    I have a lot China relays that I to replace with good ones made in the USA
    Quote Originally Posted by Iain P View Post
    6th
    May 2015
    Barre Town, VT
    [QUOTE=smithdoor;8610865]It how long will last at 30 amps
    6th[/QUOTE
    Mine's going on 6 years and 100+ Lbs of wire so I'd say a good long while but there's no guarantee. If I was to replace it I'd go with an inclosed relay to keep grinding dust out of the contacts since my welders seem to suck up a fair amount of dust.
    My "collection":
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    It is good know the HF170 does last
    The transformer will out last ever
    I look wire size used over size
    [QUOTE=Iain P;8610872]
    6th[/QUOTE
    ***************Harbor Freight 170 data
    Setting: --No Cap --- Open Circuit voltage according to manual
    Min 1 -----27.43v -----15.2v
    Min 2 -----32.30v -----16.5v
    Max 1 -----38.55v -----17.7v
    Max 2 -----48.80v -----19.2v
    150 Amp 11%
    120 Amp 17%
    110 Amp 20%
    100 Amp 25%
    80 Amp 38%
    70 Amp 50%
    64 Amp 60%
    60 Amp 67%
    50 Amp 97%
    49. Amp 100%
    Transform Wire size of sec .190”
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Would someone educate me on what the relay is for? Thanks in advance!
    SE Massachusetts
    150 Amp 11%
    120 Amp 17%
    110 Amp 20%
    100 Amp 25%
    80 Amp 38%
    70 Amp 50%
    64 Amp 60%
    60 Amp 67%
    50 Amp 97%
    49. Amp 100%
    Have to say the duty cycle on my elcheapo stick welder is MUCH better!
    Quote Originally Posted by Raybonz View Post
    This duty cycle works great for hobby work
    When had my shop most welding was done with 250 amp 60% duty cycle welder
    I also had a Miller 750 amp welder waste of money work great but never even came close to 750 amps
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Aug 2015
    south Florida
    there is a thread re this welder with mods at.
    http://weldingweb.com/showthread.php...nd-Tests/page5
    might be useful
    Choke wave with no Cap
    I have included for adding a capacitor reducing and problem with the feed board & feed motor
    I did add a capacitor to my welding
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    May 2009
    Wyoming US
    The capacitor would normally be hooked to the positive and negative of the bridge diode.
    Quote Originally Posted by Bluewelders View Post
    That why I showed on drawing
    Some will have both on the choke and on positive and negative on both sides of the choke .
    Putting a smaller capacitor on will give a good smother DC without changing the voltage must
    Sent from my SAMSUNG-SM-J320A using Tapatalk
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Apr 2018
    Nor Cal
    What's the relay for and which one did you exchange out ?
    Just the relay
    I included the capacitor just a alternate placement
    Quote Originally Posted by Bojangles07 View Post
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Apr 2018
    Nor Cal
    So wat are the %’s withe capacitor mod?
    The week part of the HF170 is the rectifier and relay.
    So use a large capacitors your need to replace your rectifier some
    As size goes around 100,000 mf will do the job.
    Most ever day welding capacitors are not need.
    The transformer had good size wire size (5GA 0.190") for the amperage
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Apr 2018
    Nor Cal
    How dose one get to these individual amperage with our settings on the MIG170
    Mig is CV the amperage is control by wire speed
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Harbor Freight is having a sale on the 170 welder $159.00
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
  25. #25
    Jan 2009
    Sonoma County
    'Liquidation' - ?
    Maybe on closeout??
    I think HF needs an entry level priced welder in their lineup, and the 125AC isn't quite up to serving that role.
    Or maybe 'Liquidation' is just marketing hype.
    HF MIG-180 with all the mods.
    Grizzly H8153 Stick/Tig Pulse 130/160.
    Wards PowrKraft AC-230. Stick & carbon arc.
