Silicone bronze tig cube
Results 1 to 13 of 13
    Apr 2018
    TN
    I put together a steel cube with silicone bronze. I've been using it a lot lately. Pretty good stuff for differential metals and nice looking joints. I like making cubes because it's good practice for heat control in small objects. Once I assembled it I flap disk it and heat treated it with my acetylene Uniweld turbo torch. Tonight I clear coated it, but I'm thinking of doing an epoxy dip instead to give it depth in the color. Before i do though, I'm wanting to bevel some holes or cut some angles into it. Not sure what to do.
Size:  91.7 KBName:  20180413_205450.jpg
Size:  43.5 KBName:  20180413_205616.jpg
Size:  47.0 KBName:  20180413_230805.jpg
Size:  53.7 KBName:  20180413_230746.jpg
    1957 Lincoln Idealarc 300 AC/DC
    1971 Miller Thunderbolt 225
    2018 Lincoln 180
    2018 Lincoln 3350 papr
    Oct 2009
    Austin TX
    Re: Silicone bronze tig cube
    The colors are cool
    Miller Syncrowave 350
    Millermatic 252/ 30A spoolgun
    Miller Bobcat 225g w/ 3545 spoolgun
    Lincoln PowerArc4000
    Lincoln 175 Mig
    Lincoln 135 Mig
    Everlast 250EX Tig
    Century ac/dc 230 amp stick
    Victor O/A
    Hypertherm 1000 plasma
    Instead of holes I think making divots filled with black or choice of color filled resin would look pretty good. That's if you are referring to making it look like a die for dice. Then you can have easy to see contrasting colors and don't have to fill the holes or the whole die with epoxy/varnish/shellac
    L-tec PCM-VPi 40A plasma
    ESAB REBEL EMP 215ic
    ESAB Mig Master 250
    Victor Performer O/A
    Mar 2014
    Nice looking cube. For making it into a die I like the idea of drilling a shallow dimple (not all the way through) filling it with Silicon Bronze and then flushing it back off with a flapper disc. You could also weld the numbers on.
    If you have a belt sander you might give using that a try as well for smoothing the welds and putting the brushed effect on the faces. The swirls do look cool though.
    ESAB Mig Master 250
    Apr 2018
    TN
    All good suggestions. I'm building another one tonight and trying out the same hammered bronze paint I used on my 1957 Lincoln. I covered the silicon bronze with Vaseline and painted the cube. Waiting on it to dry so I can wipe the silicone bronze off and see how it turned out.
Size:  82.4 KBName:  20180415_205851.jpg
Size:  41.1 KBName:  20180415_210746.jpg
    2018 Lincoln 180
    Apr 2018
    TN
    Got some of the edges cleaned up. Here is the jist of it. First time I haven't heat treated or polished a cube.
    2018 Lincoln 180
    Very Nice !!
    Sep 2009
    oklahoma city, ok
    That's awesome, why do you heat treat it and what are your procedures?
    That hammered finish and the color looks a lot like the finish on the molten poured copper anodes from a copper smelter.
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    Well done!!
    That came out nice.
    I had a friend here that did a lot of work like this with the heat coloring, he always used a very high gloss finish over his finished work. The colors he could achieve were awesome.
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    Jan 2016
    Staunton VA
    An acquaintance in Kodiak has achieved some great effects with heat --
    http://www.metallicmarineart.com
